Drive Servo with Attiny84
Hello everyone
Is it possible to use an Attiny84 to drive a servo? I understood that when I bought the Attiny84 it has 16-bit timers, and so should be able to use the Servo.h library, in the same way as an Arduino Uno?
Is that correct thinking?
If it is possible is there anything I need to know about which pins to use?
I am trying to run a Sketch that does a basic servo sweep, which works fine on the Arduino Uno but does not work on the Attiny84.
Ive checked the programming of the Attiny84 with a basic Blink sketch and it works fine.
Thanks!
You could try this:
http://forum.arduino.cc/index.php?topic=198337.msg1463365#msg1463365
crtinkerer:
Hello everyone
Yes. It has a 16-bit timer, like the Uno.
crtinkerer:
Definitely possible.
crtinkerer:
Hello everyone
Thanks!
Which clock on the Attiny84 are you using? I've read internal 1MHZ isn't enough, but I've never tried.
Check SoftwareServo library , a guy ([Solved]ATtiny 85 and servo library - Motors, Mechanics, Power and CNC - Arduino Forum) got it to work on attiny85.
Update: another guy which teaches to use the Software Servo library on Attiny85 Projects from Tech: ATtiny85 Servo: SoftwareServo Library
Take a look here: Using PWMServo_v2 lib with ATtiny84 - Microcontrollers - Arduino Forum
