here is my first post here.
I'd like to drive hdd motor at a 3600 rpm constant speed (not 3599 or 3601).
I think this kind of motor are unipolar stepper motor so I'd like to make this hardware: http://www.arduino.cc/en/Tutorial/StepperUnipolar with the uln2003
So here"s my question will I be able to reach the 3600 rpm with arduino interface
(my hdd motor is designed to work at 5400rpm)?
Will this speed be constant (assuming 3599 or 3601 is not acceptable)?
at my last question can I try to make my board alone like this:
Ok ok sorry for this misunderstanding.
Let me change my questions: I just would like to drive an electric motor to run at 3600 rpm (very very stable).
What type of motor should I use and how could I drive it?
My first goal is to have a disk turning in front of a video projector and in sync with the refresh rate.
As I asume a video refresh rate is very stable I need a very stable rotation speed to stay in sync.
Do you think it's possible ? (well dolby is able to)
So that's the bit you didn't tell us.
You can't just run a motor (or anything) and hope it will stay in sync, it simply will not no matter how stable you have the speed, it is not possible.
What you need to do is to synchronise a motor to the frame rate.
I have done this using a phase locked loop with an opto sensor on the motorised shutter acting as the VCO using normal DC servo motors.
In fact the only synchronisation I need is the motor rotation speed and the shutter glasses frame rate (120hz).
I already got the shutter synchronisation system : http://www.mtbs3d.com/phpBB/viewtopic.php?f=26&t=12596
As far as I have understood the IR signal is only used to initialize to shutter glasses (the refresh rate is fixed @ 120hz)
Do you have a schema for arduino to drive a dc motor with opto sensor to keep the motor in sync with a 60hz clock signal (60hz crystal for example)
That is exactly what I did in 1993
Look at the diagram for Twin Peeps in this link, it is a TIFF file so down load it if your browser can't cope:- http://www.doc.mmu.ac.uk/STAFF/A.Wiseman/Acorn/BodyBuild/BB93.html
My system did run at a 50Hz frame rate but there is no reason why you should not run it at 120Hz
No it is used to drive it and so keep it in sync, there is nothing free running, as I said free running at whatever degree of accuracy doesn't work with anything anywhere in the universe.
