Driver Not Found problem!
Hey guys just about to finish a project I've been working on for a long time now, but ran into a problem and hoping you guys can help!
I bought two Colorduino's (Colorduino - ITEAD Wiki) and I plugged them into a FT232R UART USB to Serial connection. I was able to properly install drivers and upload the sketch to my first board, but my second one will not find any drivers at all, and refuses to work, What is the problem and how can I fix it, they are both the same board and connecting the same way.
Are you using the same FTDI board? Windows? Have you checked your FTDI chip has not been bricked?
Also this should probably be in the installation/troubleshooting section.
Yes using the same FTDI Cable aswell even the same computer.What do you mean by bricked? How do I figure that out?
PROBLEM SOLVED PLEASE DELETE
THANK YOU
No, you can tell us how you solved the problem surely? Post a link to the solution or similar.
Yes please tell us what the problem was. Even if it was stupidity on your own part. Others may make the same mistake and benefit from your experience.
