Hello,
I am new to arduino and have a problem connecting the board to my PC. I own the AVR Playground (ATmega328P) from elektor. The instruction says I should choose "Arduino Pro or Pro Mini" and then select the port, but i cannot choose any port. When I connect the board to my PC my PC cannot find any driver. I tried the standard way Device Manager > Properties > Update Driver > (then I chose the Arduino folder on C:/Programs(x86)) but it cannot find any fitting driver...
My PC only got USB 3.0 or USB3.1 Ports, the board is connected via USB 2.0 -> Micro USB... cable - can this be the problem?
Does anyone has any idea on what i can do? Thank you!
More information to the board:
I selected the switches as showed in a tutorial
S24: everything on neutral
S33: 3 on +, everything else on neutral
S27: 1,2 on neutral, everything else on -
S15: 2,3 off
S25: 1 off
S28: PRG Mode
