I have an AEM wideband exhaust gas gauge in my car and it looks good. I also have an AliExpress boost gauge, which sucks. Or blows, depending on the boost. But either way, I want to change the boost gauge for something better. I have an empty AEM gauge housing and I want to make a PCB fitting that housing, with a pressure sensor and a lot of LED's, like the AEM WB gauge.
For the value, the gauge gets a lot of LEDs:
1 for the dot between the first and second digits, when in bar mode
1 for the dot between the second and third digits, when in PSI mode
1 for a minus, in the settings I want to be able to chose relative or absolute pressure
3x 7 for three digits
In the AEM gauge, as in my design, all LEDs are directly mounted to the PCB and the light is shining through holes in the face plate.
The ring of LEDs around the edge of the gauge face consists of 25 more LEDs.
The three digits I can each give a 74HC595 7-segment driver.
The dots and minus I think I should drive direct from the Arduino.
The outside ring, I hope to find an IC (or multiple 'in series') that can be run with only a few Arduino outputs.
I plan on using a MPXH6400AC6T1 as pressure sensor and maybe put in a light sensor to control LED brightness. It should be able to run in four modi;
- in bar, absolute
- in bar, relative (so below zero when not in boost)
- in PSI, absolute
- in PSI, relative (so below zero when not in boost)
With a simple push button to scroll throught the modi.
For the Arduino itself, I consider the Nano. I hope to desolder the processor with the bootloader already on it and resolder it on my board. My board should contain all parts the Nano board does.
Anyway, that's the plan, please advise about the ICs and about the Arduino board / processor. I also consider to go full ATmega2560 on the board, and drive each LED individually.
Thanks,
Hugo
