Driving 6 servos on a Arduino Nano PD6 not working
Hello,
I try to run 6 servos on an Arduino nano.
Every's working fine (port PD2 - PT5 and PT7) except running a servo on PD6.
Here is my code:
#include <Servo.h>
Servo Servo01, Servo02,Servo03, Servo04,Servo05, Servo06;
int ServoPin01=2 , ServoPin02=3 ,ServoPin03=4 ,ServoPin04=5 ,ServoPin05=5 ,ServoPin06=7;
  Servo01.attach(ServoPin01);
  Servo02.attach(ServoPin02);
  Servo03.attach(ServoPin03);
  Servo04.attach(ServoPin04);
  Servo05.attach(ServoPin05);
  Servo05.attach(ServoPin06);
  delay(6000);
  Serial.println("Start cycle");
  Servo01.write(0);
  Servo02.write(0);
  Servo03.write(0);
  Servo04.write(0);
  Servo05.write(0);
  Servo06.write(0);
  delay(2000);
  Servo01.write(180);
  Servo02.write(180);
  Servo03.write(180);
  Servo04.write(180);
  Servo05.write(180);
  Servo06.write(180);
  delay(2000);
I have no idea what's the problem.
Must there be a special setting to run on PD6 port?
How are the servos powered ?
Can you see something repetitive here?
You are using pins 2, 3, 4, 5, 5, 7.
..................................................| problem?
Tom... :smiley: :+1: :coffee: :australia:
Hi UKHeliBob,
thanks for your answer.
They are powered on a powersuply with 2.4A.
Maybe that is not the problem.
It's funny because I can run the servo on each port except the PD6.
So I connect only one servo on each prot seperately.
When I connect to PD6 there is nothing happens. It's the same problem on an other ARDUINO Nano too.
Hi TomGeorge,
thanks for your hint.
I corrected the code but there is still this problem.
Posting schematics might help out.
Write some code that just turns pin 6 ON and OFF each second.
See if you can see the voltage going up and down with a DMM, or a LED and resistor.
A picture(s) of your project would help to, let us see you component layout.
Repetitive again.
Two Servo05 to attach.
Tom.. :smiley: :+1: :coffee: :australia:
Hi TomGeorge,
thanks a lot for your answer.
Yes thism was my fault.
I corrected it and now it works.
Thanks to all of you for your support.
It will be easier with an array. It is still possible to do something with a specific servo, as in the loop(), or with a for-loop, as in setup():
#include <Servo.h>
Servo servo[6];
int servoPins[6] = {2,3,4,5,6,7};
  for( int i=0; i<6; i++)
    servo[i].attach(servoPins[i]);
  servo[0].write(0);
  servo[1].write(0);
  servo[2].write(0);
  servo[3].write(0);
  servo[4].write(0);
  servo[5].write(0);
  delay(2000);
  servo[0].write(180);
  servo[1].write(180);
  servo[2].write(180);
  servo[3].write(180);
  servo[4].write(180);
  servo[5].write(180);
  delay(2000);
The sketch in Wokwi simulator:
Hi Koepel,
thanks! you are right! But this works for a dirty sketch too.
