Hello,
I am very new in micro-controller programming, just had some course at university for some years ago, but have a rather good knowledge about analog electronics. I am writing here to have some advises on which Arduino platform to chose for my application. I am looking for a micro-controller/FPGA to perform the following task (see attached drawing). Basically I would like to send Pulse Width Modulated pulses to drive a set of 6 LED (maybe more in the future) and a camera based on a trigger signal that is periodical or close to periodical. I would like the pulses to be TTL compatibles and with voltages at least > 3 Volts. I will need pulses with ON durations as short as 100 us and maybe as long as 100 ms. The frequency of my trigger signal will be located between 1 to 20 Hz. My application is not lightning, and I requires a rather high timing precision and a very low jitter between the different pulses (jitter < 100 us). In addition, I am aiming at using LED driver for the LED because I need a rather high current, so the pulses will have to be able to drive TTL compatibles devices.
I was wondering what kind of Arduino platform, if any, would suit to my needs? I was also wondering if there were any possibilities to grab camera images using Arduino?
Thanks for the help.
Greg
doc1.tif (123 KB)
