Driving a step motor to control float switch
#include <Stepper.h>;
// sets constant intervals. sPR sets how far a revolution is for the stepper
const int stepsPerRevolution = 2052 ;
// sets the pin that checks the float switch
const int analogInPin = 0;
// resets clockwise rotation and counterclockwise. Set during later loops.
int rotationCW = 0;
int rotationCCW = 0;
// variable that corresponds to how far the switch has moved.
int floatSwitch = 0;
int location = 1;
// sets variable for stepper
Stepper myStepper = Stepper(stepsPerRevolution, 8, 10, 9, 11);
// setup for more stepper motor variables
  myStepper.setSpeed(15);
// loop to read the digital pin that the floatswitch is connected to
  floatSwitch = digitalRead(6);
  Serial.print("floatswitch = ");
  Serial.println(floatSwitch);
// if the floatswitch is on, this turns the gear to reduce water flow
if (floatSwitch == 1 && location == 1)  {
rotationCW = 0.5 * stepsPerRevolution;
Serial.println("clockwise");
myStepper.step(rotationCW);
location = 2;
Serial.print("location = ");
Serial.println("At Location 1");
// if the floatswitch is turned off and the gear has been moved, this moves the gear back to
// return it to its regular flow rate.
else if (floatSwitch == 0 && location == 2); {
  rotationCCW = -0.5 * stepsPerRevolution;
  Serial.println("counterclockwise");
  myStepper.step(rotationCCW);
  location = 1;
  Serial.println("At Location 2");
else if (floatSwitch == 1 && location == 2 {
  delay(1000)
  rotationCCW = 0
