Driving a stepper multiple defined number of steps.
Hello all, new to the forum but I have been lurking for a while and trying to learn as I go.
I have run into an issue where I would love to have some advice.
In this project I would like to drive a stepper using the Eazydriver a pre-determined number of steps and once that line of code is executed, if need be drive the stepper another but different pre-determined number of steps using an input to start the movement.
Is this even possible?
I have tried several different approaches to accomplishing this goal but seem to fall short every time.
Below is an example of the test code.
Thank You in advance!
#define DISTANCE 384
#define DISTANCE2 24
int StepCounter = 0;
int StepCounter2 = 0;
int Stepping = false;
int Singlestepping = false;
  pinMode(8, OUTPUT);
  pinMode(9, OUTPUT);
  digitalWrite(8, LOW);
  digitalWrite(9, LOW);
  pinMode(3, INPUT);
  pinMode(4, INPUT);
  if (digitalRead(3) == LOW && Stepping == false)
    Stepping = true;
  else if  (digitalRead(4) == LOW && Singlestepping == false)
    Singlestepping == true;
  if (Stepping == true)
    digitalWrite(9, HIGH);
    delay(10);
    delay(10);
    StepCounter = StepCounter ++; 1;
    if (StepCounter == DISTANCE)
      StepCounter = 0;
      Stepping = false;
    if (Singlestepping == true)
      delay(10);
      delay(10);
      StepCounter2 = StepCounter2 ++; 1;
      if (StepCounter2 == DISTANCE2)
        StepCounter2 = 0;
Try this ( modifications at lines 39, 41, 54 and 56):
  pinMode(8, OUTPUT);
  pinMode(9, OUTPUT);
  pinMode(3, INPUT);
  pinMode(4, INPUT);
    Stepping = true;
    delay(10);
    delay(10);
    //StepCounter = StepCounter ++; 1;
    if (++StepCounter >= DISTANCE)
      StepCounter = 0;
      Stepping = false;
      delay(10);
      delay(10);
      //StepCounter2 = StepCounter2 ++; 1;
      if (++StepCounter2 >= DISTANCE2)
        StepCounter2 = 0;
This is exactly the sort of thing the AccelStepper library makes easy - you can initiate a move whenever you want and it will happen automatically in the background (so long as you call the run() method frequently, ie in the
loop() function).
Have a look at the examples for AccelStepper library (you'll need to download it).
