Hello,
I would like to build a simple mechanical option to block a laser beam. Ideally, a switchable element that would block or free the path of the beam, with seconds to minutes between switches.
A solenoid would just do the job and I selected an Adafruit 413 Large solenoid (Large push-pull solenoid : ID 413 : $14.95 : Adafruit Industries, Unique & fun DIY electronics and kits).
I have a L298N h-bridge driver board that I use to test motors. I have read other users posting about using this driver board to control solenoids, but I am not 100% sure this would work for the case described above.
I also found a few blog post such as this https://www.instructables.com/id/Controlling-solenoids-with-arduino/
or this : https://core-electronics.com.au/tutorials/solenoid-control-with-arduino.html
that describe a pretty simple way to connect and control solenoids. If this is a better way to control an Adafruit 413, what board should I use to drive power and logic?
Thanks,
If only the product link you provided had driver instructions. Oh wait! It does!!!
It does not need an H-bridge. It has a return spring.
vinceherman:
http://playground.arduino.cc/uploads/Learning/solenoid_driver.pdf
Thanks for the answer!
I was looking for that in the product page but I see it was not the right place.
The diagram describe one of the methods I posted.
Any chance there is a board out there where these components are already soldered?
For example, when I was looking for a driver for our DC Brushed motor, I got the L298N board in the picture below
I was wondering if there is an equivalent for the portion of the driver in the picture below (which is a screenshot of your link)
If someone else is already selling a pcb module with all components, I would directly buy that.
Thank you!
Update: in case anyone is looking at this for their own ideas, at the moment I bought the single component and a breadboard and I am using the scheme that vinceherman posted.
