Hello there , i need some advice and comments in my thoughts on how to Drive an Analog 0-10v light Ballast with an 5v PWM arduino..
i am using the IRL540N MOSFET latetly in projects as a driver when i want to pass voltage easy with arduino...
So in order to drive the ballast with analog 0-10v i will probably need a Ac/Dc adaptor 10V as the power source , the driver will be the MOSFET and the arduino will do the dimming...
You're supplying 10v as a constant, and using pwm to switch the ballast on and off, 0 off 10v on, it's not going to give a 0-10v range which I think you want, having said that ..
If the load is controlled by the mosfet and not a circuit expecting a voltage in which it varies the output it should work... eg if 1v was supplied and it worked, then a capacitor could be used to vary it's voltage to the ballast via pwm.
what i want is 0-10v Range , in order to Dim .. the particular MOSFET does that..
