Driving an used Step-Syn stepper
I have a used Step-Syn stepper motor. The name plate rates it as 1.4 A, 4.5 volts.
Can I run this stepper motor with the Arduino TB6600 driver using 12v and limiting the current to 1.5 amps?
duinoMike:
That should be fine.
...R
Stepper Motor Basics
Simple Stepper Code
Great!
Thanks
1.5 is larger than 1.4 - older stepper motors are easy to demagnetize if you over-current them, so don't.
Older motors use Alnico magnets, not rugged ceramic or neodymium. You also should not take such a motor apart without the proper "keeper" to protect the rotor from demagnetizing.
