driving DC motor with encoder to scan a sector with constant speed
Please read
slam 3likm w ra7mt allah w brkato;
Hi ;
Iam trying to drive dc motor has an encoder with constant speed in certain direction and when reach the end of the sector , the signal on 3,5 pins will be will reversed so the motor will reverse direction.the counter counts the input pulsese from the encoder,so every interrupt on pin 2 , the counter will be increased by 1 or decreased by 1 based on the direction.
When i see the output on an oscilloscope , the signal is right in half and wrong in the other this means that the error in the point where i reverse the direction
Please help thank you
this is the code:
/*driving dc motor in certain sector with varying speed for scanning*/
 int on_off=A1;        //  switch pin
 int leftled=A2;       //  led indicate to left motion
 int rightled=A3;      //  led indicate to right motion
 int potspeed=A4;      //  speed potentiometer PIN
 int potsector=A5;     //  sector potentiometer PIN
 int pulse=2;          //  input pulse from decoder
 int c1 =3;            //  c1 output to drive to left
 int c2 =5;            //  c2 output to drive to right
 volatile int speeed=0;         //  variable carry the speed value
 volatile int sector=0;         //  sector width
 volatile byte(counter)=00000000;        //  antenna assumed to start motion to left
 volatile int left_direction=1;             //  indicator represents motion to left direction
 volatile int right_direction=0;             //  indicator represents motion to right direction
 int s=1;              //  represents the switch state
 int store=0;
  pinMode(c1,OUTPUT);             // Driver contorl signal for left
  pinMode(c2,OUTPUT);             // Driver contorl signal for right
  pinMode(pulse,INPUT);           // input pulses from sensor
  pinMode(on_off,INPUT);          // switch pin
  pinMode(potspeed,INPUT);        // speed potentiometerr pin as an input
  pinMode(potsector,INPUT);       // sector potentiometer pin as an input
  pinMode(leftled,OUTPUT);        // left led as output
  pinMode(rightled,OUTPUT);       // right led as output
  digitalWrite(leftled,LOW);      // initializes the led signals
  digitalWrite(rightled,LOW);     // initializes the led signals
  analogWrite(c1,LOW);            //initializes the driving signals
  analogWrite(c2,LOW);            //initializes the driving signals
  speeed=50;
  sector=100;
  attachInterrupt(0,decoder,RISING);            // pin 2 is the input from sensor to make the interrupt to work
 if(on_off==HIGH)                  // make S depends on the on_off pin state
     {s==1;}
 else{s==0;}
  left:
     analogWrite(c1,speeed*s);
      digitalWrite(leftled,HIGH);
    if(left_direction==1 && right_direction==0)
     if(counter  >= sector)
       analogWrite(c2,speeed*s);
       left_direction==0;
       right_direction==1*s;
       digitalWrite(rightled,HIGH);
       goto right;}
       else {goto left;}         // if angle does not reach the maximume
   right:
       if(left_direction==0 && right_direction==1)
     if(counter==0)
       left_direction==1*s;
       right_direction==0;
   else{goto right;}          // if angle does not reach 0
  //end of the main loop
 void decoder()                       // the function that would be perfomed after the interrupt occurs
   speeed=50;
   sector=100;
   if(left_direction==1&&right_direction==0)                  // if motion to left
     counter--;
   }                   //if motion to right
      counter++;
 detachInterrupt(0);
I would definitely call attachInterrupt() once in setup().
I do not know if i have to state it one in the set up or not .
the motor will rotate in between encoder pulse and so the pulses will come to pin 2 and they must be counted
Do not do this:-
detachInterrupt(0);
and as Mark says only do this:-
Once in the setup function, no where else.
it is used to get out of the interrupt
ahmed_abdellatif:
You do not need this to get out of an interrupt.
i want to test it , is there is a simultor ?
Just google Arduino simulator
i can not use it it does not work :(((
ahmed_abdellatif:
What does not work the simulator or google? There is more than one simulator.
what is ment by
Start a terminal window and maximize the size of the terminal window.
unzip simuino_.zip
cd simuino
./simuino
These are instructions for using the command line on your computer. Terminal is a Unix terminal session. CD is an instruction to change directory and ./ means execuited the file who's name follows in this case simulno
