Not wanting to be a smart-ar$e... if both, sink and source, what do you suggest is being done differently?
I may not understand the difference. I thought sink vs. source relates to what is being switched; with source is what I showed in the O.P., and sink with the load being below the transistor (emitter to ground)?!
A circuit that would source current would use a PNP transistor and the load would be connected to ground.
That is how the ICs work (except with MOSFETs rother than BJT), they have both a PMOS and NMOS circuit connected to the pin, so it can source and sink current
