Driving leds and speaker
Hi, I'm planning a project, and I want to double check it before building the prototype, I'm very new at this and I dont want to fry my arduino.
The arduino will use some sensor data to play tones on the speaker, light 2 leds (both led do the same), and move a servo.
Anyone see something out of place? will I burn something?
Thanks.
You can't use the RST line to drive an LED.
A 2N3907 is an NPN transistor and you have drawn a PNP transistor.
I would not use that circuit for the speaker, there is lots wrong with it.
Sorry my bad, I confuse pin numbers, and there were 3906.
I just need a simple sound generator with minimal parts. Could you explain what could be wrong with this please. I will be using a small speaker.
It puts DC through the speaker, which is bad.
It puts too much DC through the speaker which is double bad.
While it is not perfect this is a much better circuit to use.
