Driving multiple relays independently with the same analog input
I am sorry if this is a noob question but is it possible to drive 2-3 relays using the same analog input from a sensor without using any shift registers? I am using an electret mic as a sensor, currently turning on/off fairy lights with a solid state relay when values of sensor go over a specific threshold. I want it to do the same to 2 other relays but using a higher threshold. Would I need a shift register or can I just adjust the code. The code I am using currently is the following:
//electret mic input
int sensorPin = 0;    //Microphone Sensor Pin on analog 0
int Relay = 8;
int Relay2 = 9;
int sensorValue = 0;
pinMode(Relay, OUTPUT);
pinMode(Relay2, OUTPUT);
  // read the value from the sensor:
  sensorValue = analogRead(sensorPin);
Serial.println(sensorValue);
  if (sensorValue>380){
    digitalWrite(Relay,HIGH);
    delay(100 );
    digitalWrite(Relay,LOW);
  if (sensorValue>500){
    digitalWrite(Relay2,HIGH);
    delay(100 );
    digitalWrite(Relay2,LOW);
If your mike is giving enough signal it should work
int sensorPin = A0;    //Microphone Sensor Pin on analog 0
int Relay1 = 8;
int Relay2 = 9;
int Relay3 = 13;  // build in  LED
  pinMode(Relay1, OUTPUT);
  pinMode(Relay3, OUTPUT);
  Serial.println("relays controlled by microphone");
  Serial.print("Sensor raw: ");
  if (sensorValue > 380)
    digitalWrite(Relay1, HIGH);
    digitalWrite(Relay1, LOW);
  if (sensorValue > 500)
    digitalWrite(Relay2, HIGH);
    digitalWrite(Relay2, LOW);
the relay logic can also be implemented this way // this works because HIGH == 1 == TRUE // digitalWrite(Relay1, (sensorValue > 380)); // digitalWrite(Relay2, (sensorValue > 500)); // digitalWrite(Relay3, (sensorValue > 750)); // delay(1000);
give it a try
