Driving Servo Sinusoidally
Here's a small function I use to generate a sine wave with a digital to analog converter (DAC).
uint16_t sin_wave[128];
  for (int16_t i = 0; i < 128; i++)
    float angle = TWO_PI * i / 128;
    int16_t val = sin(angle) * (2048 - 1);
    val += 2048;
    sin_wave[i] = val;
128 is the number of steps (the granularity of your sine wave). 2048 is the waveform zero point offset.
The next step is to pass these values in a sweep from 0 to 127 to the output with an appropriate delay between each step. You could use a similar technique for just about any waveform. Either pre compute the steps or just compute and feed the values directly to your output as you go.
