Driving Servo With ATtiny84A, Only Goes From 0° to 45°
I suspect it has something to do with the PWM frequency being different from the Arduino itself, because when I run the same servo program on my Uno, it works fine. But, as the title says, on my ATtiny, it will start at 0 and only go to about 45. It will keep sending a signal, however, and my servo gets hot.
I'm running it at 8mhz, I have my output on one of the chip's PWM pins, and I'm using the SoftwareServo library.
Any help here? Apologies if this is the wrong category. I can send code and pictures if necessary.
Are you using Attinycore?
it supports servo without an additional library.
Posting your code in codetags is always a good idea.
I don't have ATtiny84. I have executed the following sketch using DigisprakATtiny85 Board (Fig-1, 2), and the SG-90 Servo Motor turns from 00 to 1800 (Fig-3).
#include <Servo_ATTinyCore.h>
Servo myservo;  // create servo object to control a servo
// twelve servo objects can be created on most boards
int pos = 0;    // variable to store the servo position
  myservo.attach(1);  // PB1
  for (pos = 0; pos <= 180; pos += 1)
    myservo.write(pos);              // tell servo to go to position in variable 'pos'
    delay(15);                       // waits 15ms for the servo to reach the position
  for (pos = 180; pos >= 0; pos -= 1)
DigisparkAttiny85Board
Figure-1:
Figure-2:
Figure-3:
Yes, I've tried it with SoftwareServo and the default library that comes installed with the IDE, they both produce the same result. But yes, I'm using ATTinyCore.
Here's the code:
#include <Servo.h>
Servo myservo;
  myservo.attach(A6);
    for (int i = 0; i < 180; i++) {
        myservo.write(i);
        delay(15);
I can post a picture of my circuit if necessary.
There is a chance that your IDE includes another servo library than the one that comes with Attinycore.
better use this include:
Servo myservo;
  myservo.attach(A6);
        myservo.write(i);
        delay(15);
Just tested with a Attiny84a and I get:
  • 552 us servopulse for 0 degrees
  • 1481 us servopulse for 90 degrees (mid point)
  • 2409 us servopulse for 180 degrees
All at 50Hz, so it is not your code that is misbehaving.
I am using IDE 1.8.19 portable with Attinycore 1.5.2
edit: and you don't forget to do "burn bootloader" to set the fuses right, before you upload your sketch?
that solved it. Thanks man
