Driving stepper motor blocks MPU6050 from computing correct angle
I am working on a proof-of-concept experiment that is using an MPU6050 (just to compute roll value) to drive a stepper motor with PID control (roll value as input, speed of stepper motor as output). I am using the Electronic Cats MPU6050 library to get my roll value (runs with interrupts), and then the AccelStepper library to drive the stepper motor. Here is my issue:
When the roll value gets too far away from the PID setpoint, 0, my variable "roll" (computed in the interrupt) stops being the right value. If I comment out the line that actually drives the motor -"stepper.setSpeed(Output);" - at the bottom of my main loop, the issue goes away. So I suspect that setSpeed() or an associated function is somehow blocking my interrupt, and then the ISR is miscalculating roll because the time since the last ISR is inaccuate. However, I don't understand how this could happen because I thought the interrupt should always have priority over anything else that my code is doing. Please let me know if anyone has a suggestion for how to fix this or an explanation for why it isn't working.
Here is the Accelstepper documentation. I also attached my entire code. Let me know if any other information is needed. I am using an Uno. Thank you!
https://www.airspayce.com/mikem/arduino/AccelStepper/classAccelStepper.html
// Reactionary moment arm proof of concept
// using Accelstepper, MPU6050, PID libraries
//stepper
#include <AccelStepper.h>
//IMU stuff
#include "I2Cdev.h"
#include "MPU6050_6Axis_MotionApps20.h"
#include "Wire.h"
//PID
#include <PID_v1.h>
//stepper
AccelStepper stepper(2, 8,9);
unsigned long steptimer = 0;
unsigned long oldsteptimer = 0;
// MPU vars
MPU6050 mpu;
#define INTERRUPT_PIN 2
bool dmpReady = false;  // set true if DMP init was successful
uint8_t mpuIntStatus;   // holds actual interrupt status byte from MPU
uint8_t devStatus;      // return status after each device operation (0 = success, !0 = error)
uint16_t packetSize;    // expected DMP packet size (default is 42 bytes)
uint16_t fifoCount;     // count of all bytes currently in FIFO
uint8_t fifoBuffer[64]; // FIFO storage buffer
Quaternion q;           // [w, x, y, z]         quaternion container
VectorInt16 aa;         // [x, y, z]            accel sensor measurements
VectorInt16 aaReal;     // [x, y, z]            gravity-free accel sensor measurements
VectorInt16 aaWorld;    // [x, y, z]            world-frame accel sensor measurements
VectorFloat gravity;    // [x, y, z]            gravity vector
float euler[3];         // [psi, theta, phi]    Euler angle container
float ypr[3];           // [yaw, pitch, roll]   yaw/pitch/roll container and gravity vector
volatile bool mpuInterrupt = false;     // indicates whether MPU interrupt pin has gone high
void dmpDataReady() {
    mpuInterrupt = true;
float pitch;
float roll;
//PID
double Pk = 10;
double Ik = 0;
double Dk = 1;
double Setpoint = 0.0, Input, Output;
PID pid(&Input, &Output, &Setpoint, Pk, Ik , Dk, REVERSE);
unsigned long t;
// ****************** SETUP ******************************
  pinMode(2, INPUT_PULLUP);
  // IMU Setup
  // join I2C bus (I2Cdev library doesn't do this automatically)
  #if I2CDEV_IMPLEMENTATION == I2CDEV_ARDUINO_WIRE
    Wire.begin();
    Wire.setClock(400000); // 400kHz I2C clock. Comment this line if having compilation difficulties
    Wire.setWireTimeout(3000,true);
  #elif I2CDEV_IMPLEMENTATION == I2CDEV_BUILTIN_FASTWIRE
    Fastwire::setup(400, true);
  #endif
  // initialize device
  mpu.initialize();
  devStatus = mpu.dmpInitialize();
  // supply your own gyro offsets here, scaled for min sensitivity
  mpu.setXGyroOffset(177);
  mpu.setYGyroOffset(-30);
  mpu.setZGyroOffset(-89);
  mpu.setXAccelOffset(-4105);
  mpu.setYAccelOffset(-2437);
  mpu.setZAccelOffset(507);
  // make sure it worked (returns 0 if so)
  if (devStatus == 0) {
    mpu.CalibrateAccel(6);
    mpu.CalibrateGyro(6);
    // turn on the DMP, now that it's ready
    mpu.setDMPEnabled(true);
    // enable Arduino interrupt detection
    attachInterrupt(digitalPinToInterrupt(INTERRUPT_PIN), dmpDataReady, RISING);
    mpuIntStatus = mpu.getIntStatus();
    dmpReady = true;
    // get expected DMP packet size for later comparison
    packetSize = mpu.dmpGetFIFOPacketSize();
  else {
    //Serial.println("bad");
  pid.SetMode(AUTOMATIC);
  pid.SetOutputLimits(-1000, 1000);
  pid.SetSampleTime(10);
  stepper.setMaxSpeed(1000);
}   // end of setup
// ********************* MAIN LOOP *******************************
  if (!dmpReady) return;
  //calc roll
  if (mpu.dmpGetCurrentFIFOPacket(fifoBuffer)) {
    mpu.dmpGetQuaternion(&q, fifoBuffer);
    mpu.dmpGetGravity(&gravity, &q);
    mpu.dmpGetYawPitchRoll(ypr, &q, &gravity);
    roll = (ypr[2] * 180/M_PI);
    Serial.print("roll: ");
    Serial.println(roll);
   Input = roll;
   pid.Compute();
   //Serial.print("     output: ");
   //Serial.println(Output);
   steptimer = millis();
   if ((steptimer - oldsteptimer) > 10){
      oldsteptimer = steptimer;
   stepper.runSpeed();
More people will respond to your post if you follow the forum rules and post the code in line, using code tags.
I took a look and the code to calculate roll is extremely unwieldy, and entirely unnecessary for (approximately) static measurements. No interrupt is needed. The code below shows how to calculation pitch and roll accurately and efficiently with the MPU-6050.
// minimal MPU-6050 tilt and roll (sjr). Works with MPU-9250 too.
// works perfectly with GY-521, pitch and roll signs agree with arrows on sensor module 7/2019
// Tested with 3.3V eBay Pro Mini with no external pullups on I2C bus (worked with internal pullups)
// Add 4.7K pullup resistors to 3.3V if required. A4 = SDA, A5 = SCL
#include<Wire.h>
const int MPU_addr1 = 0x68;
float xa, ya, za, roll, pitch;
  Wire.begin();                                      //begin the wire communication
  Wire.beginTransmission(MPU_addr1);                 //begin, send the slave adress (in this case 68)
  Wire.write(0x6B);                                  //make the reset (place a 0 into the 6B register)
  Wire.write(0);
  Wire.endTransmission(true);                        //end the transmission
  Wire.write(0x3B);  //send starting register address, accelerometer high byte
  Wire.endTransmission(false); //restart for read
  Wire.requestFrom(MPU_addr1, 6); //get six bytes accelerometer data
  int t = Wire.read();
  xa = (t << 8) | Wire.read();
  t = Wire.read();
  ya = (t << 8) | Wire.read();
  t = Wire.read();
  za = (t << 8) | Wire.read();
// formula from https://wiki.dfrobot.com/How_to_Use_a_Three-Axis_Accelerometer_for_Tilt_Sensing
  roll = atan2(ya , za) * 180.0 / PI;
  pitch = atan2(-xa , sqrt(ya * ya + za * za)) * 180.0 / PI; //account for roll already applied
  Serial.print("roll = ");
  Serial.print(roll,1);
  Serial.print(", pitch = ");
  Serial.println(pitch,1);
  delay(400);
Sorry about that, edited my original post. Thanks for the response. Not sure what you mean by "static measurements," but the final application will be moving around translationally so I think all the anti-drift measures and such are needed. Also the code you posted uses a big delay, and I don't think that will work because I need to also be driving my stepper motor at a max of one step per loop, which means the loop has to run many times a second. The code for reading the imu works great as it is anyway, it's just when combined with driving the stepper that there are problems.
The introduced errors depend on the acceleration and/or rotation rates.
Given no project details, forum members couldn't possibly guess whether you are correct. And you certainly won't know if you don't try.
Incidentally the MPU-6050 was discontinued years ago. Whatever you have is almost certainly a clone, with no guarantee of adherence to the specs in the original data sheet.
Good luck with your project!
Well I told you what I need my code to do, if you want more details I can provide them. Delaying for 400 ms every loop iteration definitely will not work for the reason I stated. I think having the angle calculation on an interrupt is the right solution. My imu works perfect it is just that one line of code that is breaking it. Do you think you could take a look at that part?
Oh come on. Did you take that delay statement seriously? That is a simple example program, with a delay for ease of reading while the numbers fly by.
As I said, you are using a part that is long obsolete, and undoubtedly have a clone that is not guaranteed to meet original specs, or to run code intended for the original part. I have no interest to debug it.
Ok...
Again that isn't where the issue is. Maybe somebody else can help.
