Driving two 6v 500 ohm motors
I've got two motors which I can use to rotate a wheel. However, these are 6 volt, and the Arduino only outputs 5 volt. I checked the resistance and it's approximately 500 Ohm.
I tried driving them but nothing happened. How do I change the voltage to 6 volt? I do realize that it won't be as powerful.
Driving things that use more current than 40mA on a single pin is not good for the arduino, check, how much current it takes :wink:
(The pins can be damaged)
That's why the thing motorshield was invented :wink:
The best way to do this is to get a npn transistor and connect the middle pin to a pwm pin on the arduino, powersorce and motor to the other legs of the transistor
a diode across the motor will help
here is a site that helps:
http://todbot.com/blog/bionicarduino/
more specific on the motor control:
http://todbot.com.s3.amazonaws.com/bionicarduino/bionic_arduino_class3.pdf
Read this pdf from page 6 and onwards (powerpoint slide size so it won't take long)
David
