Hi, I'm writing a code with html for a login page in order to get wifi ssid and password from user and connect esp32 to a local modem using a mobile phone as a medium. when i click on the ssid section the drop down menu is populated correctly by the server side and is shown. the problem is that these ssids are not selectable and when i click on them nothing happens. i tried googling and asking AI for help but it didnt work. here is my html code
<!DOCTYPE html>
<html lang="en">
<head>
<meta charset="UTF-8">
<title>Wi-Fi Selection</title>
<link rel="stylesheet" href="./normalize.min.css">
<link rel="stylesheet" href="./style.css">
</head>
<body>
<form action="/get" name="Divertpage" class="form-horizontal login-form">
<div class="form-group relative">
<div class="form" id="form">
<div class="field email">
<div class="icon"></div>
<fieldset>
<label>انتخاب شبکه مورد نظر</label>
<input autocomplete="off" role="combobox" list="ssidList" id="input" name="ssid" placeholder="شبکه مورد نظر را انتخاب کنید">
<!-- The list attribute should match the id of the datalist -->
<datalist id="ssidList" role="listbox">
</datalist>
</fieldset>
<div class="field password">
<input class="input" id="password" type="password" placeholder="رمز عبور"/>
</div>
<button class="button" type="submit" onclick="WaitPls()">ذخیره
<div class="side-top-bottom"></div>
<div class="side-right-left"></div>
</button>
<small>فرم را پر کنید</small>
</div>
</div>
</div>
</form>
<script src='./jquery.min.js'></script>
<script src="./script.js"></script>
<script>
// Fetch scanned Wi-Fi networks and populate the dropdown
function fetchWifiNetworks() {
fetch('/wifi_scan')
.then(response => response.text())
.then(data => {
document.getElementById('ssidList').innerHTML = data;
// Call fetchWifiNetworks on page load
window.onload = fetchWifiNetworks;
function WaitPls() {
var ssid = document.forms["Divertpage"]["ssid"].value;
var password = document.forms["Divertpage"]["password"].value;
if (ssid == "") {
// alert("نام کاربری را وارد نمایید.");
return false;
} else if (password == "") {
// alert("رمز عبور را وارد نمایید.");
return false;
// Redirect to waiting page after form submission
window.location.href = "/Wait";
</script>
<script>
var input = document.getElementById('input');
var ssid = document.getElementById('ssidList');
input.onfocus = function () {
ssid.style.display = 'block';
input.style.borderRadius = "5px 5px 0 0";
input.oninput = function() {
var text = input.value.toUpperCase();
for (let option of ssid.options) {
if(option.value.toUpperCase().indexOf(text) > -1){
option.style.display = "block";
option.style.display = "none";
option.onclick = function () {
input.value = option.value;
ssid.style.display = 'none';
input.style.borderRadius = "5px";
var currentFocus = -1;
function addActive(x) {
if (!x) return false;
removeActive(x);
if (currentFocus >= x.length) currentFocus = 0;
if (currentFocus < 0) currentFocus = (x.length - 1);
x[currentFocus].classList.add("active");
function removeActive(x) {
for (var i = 0; i < x.length; i++) {
x[i].classList.remove("active");
</script>
</body>
</html>
And here is the related task from server side
void wifiScanTask(void *parameter)
while (true)
Serial.println("scanning networks");
int n = WiFi.scanNetworks();
if (n > 0)
scannedNetworks = "<option value=\"\">انتخاب شبکه مورد نظر</option>";
for (int i = 0; i < n; ++i)
scannedNetworks += "<option value=\"" + WiFi.SSID(i) + "\">" + WiFi.SSID(i) + "</option>";
if (i == (n - 1))
Serial.println("i is n-1");
wifi_scan_resume_flag=1;
first_time_scan=0;
vTaskSuspend(NULL);
scannedNetworks = "<option value=\"\">شبکه ای یافت نشد</option>";
// Wait for 10 seconds before scanning again
vTaskDelay(20000 / portTICK_PERIOD_MS);
What might be the problem here ?
Thanks in advance !
