I am using a 12v dc pump for a water distribution system, the pump runs dry sometimes which causes in damage of the pump, I have a trigger to turn off the pump after 5 seconds if the current is below
600 Milliamp, now there is something that the motor current wouldn't drop from 1000 or above in 5 seconds and the pump is running continuously dry. The pump current, while it's running dry sometime the current is above 1000 milliamp, this confuses me.
How can I avoid the pump from getting damaged while running dry?
Cheers,
IF your pump is completely submersed in water, then it is using water for bearing lubrication.
I have used a vacuum switch on the pump suction inlet to switch off after a certain delay after suction loss, but don't know anything about your pump and situation. Post some details.
Water level switch in the pipework seems a good bet to me - a float switch may be over sensitive to
flow or contaminants, I suspect there's a capacitive sensor that would be more robust available.
Differential pressure sensor across the pump might also be effective.
