Dear forum,
I'm new to arduino and this is my first topic here.
I have question about dallas 1-wire temperature sensors. I have code where i am reading 4 this DS1820 chips and displaying valuses with time stamps on serial monitor and lcd and also i am logging these data to SD card.
Everithing works OK mainly thanks to all great guys from several forums. Many thanks to them.
My only problem is that when i get temperature from DS1820 it is in format 19.25°C but i need 19,25°C. So i need decimal separator with comma not a dot ! ! !
Is this possible to fix this i my code or library, I need this because the other program I am using to analyze these data. And i trully need t fix this, so please guys hep me :~
Here is the coede:
// libraries
#include <Wire.h>
#include "RTClib.h"
#include <OneWire.h>
#include <DallasTemperature.h>
//Connection through I2C
LiquidCrystal_I2C lcd(0x20,20,4); // set the LCD address to 0x20 for a 16 chars and 2 line display
// DS18B20 sensors on I/O pin 9
#define ONE_WIRE_BUS 9
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
// Assign the addresses of your 1-Wire temp sensors.
DeviceAddress DS0 = { 0x10, 0x7C, 0xAD, 0x74, 0x02, 0x08, 0x00, 0x5E};
DeviceAddress N05 = { 0x28, 0x80, 0x02, 0x24, 0x03, 0x00, 0x00, 0xED };
DeviceAddress N10 = { 0x10, 0x5D, 0xAA, 0x74, 0x02, 0x08, 0x00, 0x8E };
// DeviceAddress N17 = { 0x10, 0xBB, 0x1B, 0x57, 0x02, 0x08, 0x00, 0x6F };
DeviceAddress N17 = { 0x10, 0xE2, 0xA5, 0x74, 0x02, 0x08, 0x00, 0xC2 };
//Constants
long ID = 1; //Use this to store the id # of our reading.
// RTC??
RTC_DS1307 RTC; // define the Real Time Clock object
uint32_t syncTime = 0; // time of last sync()
const int chipSelect = 10;// for the data logging shield, we use digital pin 10 for the SD cs line
// Logfile ?
void error(char *str)
Serial.print("Chyba: ");
Serial.println(str);
while(1);// lock up if error
// main setup
void setup(void)
// LCD I2C setup
lcd.init(); // initialize the lcd
lcd.backlight(); // blacklight of the lcd
lcd.clear(); // clear the LCD screen
// Start up the library
sensors.begin();
// set the resolution to 10 bit (good enough?)
sensors.setResolution(DS0, 12);
sensors.setResolution(N05, 12);
sensors.setResolution(N10, 12);
sensors.setResolution(N17, 12);
// RTC setup
Wire.begin();
RTC.begin();
if (! RTC.isrunning()) {
Serial.println("RTC is NOT running!");
// following line sets the RTC to the date & time this sketch was compiled
RTC.adjust(DateTime(DATE, TIME));
Serial.println("ID Cas Datum DS0 N05 N10 N17 ");
// DS1820 setup
float TempC = 0;
void printTemperature(DeviceAddress deviceAddress)
float tempC = sensors.getTempC(deviceAddress);
if (tempC == -127.00) {
Serial.print("XX.X");
lcd.print("XX.X");
lcd.print(tempC,2); // 2 means decimal places
Serial.print(tempC,2); // 2 means decimal places
Serial.print(' ');
//lcd.print(tempC);
void loop(void)
DateTime now;
// fetch the time
now = RTC.now();
Serial.print(ID); // ID na serial
Serial.print(" ");
//datum ve tvaru 19/02/2013
if (now.day() < 10) {
Serial.print("0"); //insert leading zero if day value is less than 10
Serial.print(now.day(),DEC); //display current day
else Serial.print(now.day(),DEC); //display current day
Serial.print('.');
if (now.month() < 10) {
Serial.print("0"); //insert leading zero if month value is less than 10
Serial.print(now.month(),DEC); //display current month
else Serial.print(now.month(),DEC); //display current month
Serial.print(".");
Serial.print(now.year(), DEC);
Serial.print(' ');
//cas ve tvaru 09:50:02
if (now.hour() < 10) {
Serial.print("0"); //insert leading zero if hour value is less than 10
Serial.print(now.hour(),DEC); //display current hour
else Serial.print(now.hour(),DEC); //display current hour
Serial.print(':');
if (now.minute() < 10) {
Serial.print("0"); //insert leading zero if minute value is less than 10
Serial.print(now.minute(),DEC); //display current minute
else Serial.print(now.minute(),DEC); //display current minute
Serial.print(":");
if (now.second() < 10) {
Serial.print("0"); //insert leading zero if seconds value is less than 10
Serial.print(now.second(),DEC); //display current seconds
else Serial.print(now.second(),DEC); //display current seconds
lcd.clear();
lcd.setCursor(0, 0);
lcd.print("0"); //insert leading zero if day value is less than 10
lcd.print(now.day(),DEC); //display current day
else lcd.print(now.day(),DEC); //display current day
lcd.print('.');
lcd.print("0"); //insert leading zero if month value is less than 10
lcd.print(now.month(),DEC); //display current month
else lcd.print(now.month(),DEC); //display current month
lcd.print(".");
lcd.print(now.year()-2000, DEC);
lcd.print(' ');
lcd.setCursor(12, 0);
lcd.print("0"); //insert leading zero if hour value is less than 10
lcd.print(now.hour(),DEC); //display current hour
else lcd.print(now.hour(),DEC); //display current hour
lcd.print(':');
lcd.print("0"); //insert leading zero if minute value is less than 10
lcd.print(now.minute(),DEC); //display current minute
else lcd.print(now.minute(),DEC); //display current minute
lcd.print(":");
lcd.print("0"); //insert leading zero if seconds value is less than 10
lcd.print(now.second(),DEC); //display current seconds
else lcd.print(now.second(),DEC); //display current seconds
// Zde se vypisuje trvání celého záznamu v sekundách
lcd.setCursor(9,1); // move cursor to second line "1" and 9 spaces over
lcd.print("Cas: "); // ID na serial
lcd.print(millis()/60000); // display seconds elapsed since power-up
lcd.setCursor(0, 1);
lcd.print("ID: "); // ID na serial
lcd.print(ID); // ID na serial
Serial.print(' ');
// #endif //ECHO_TO_SERIAL
sensors.requestTemperatures();
Serial.print(" ");
// delay(prodleva);
lcd.setCursor(0,2);
lcd.print("DS0:");
printTemperature(DS0);
Serial.print(" ");
//delay(prodleva);
lcd.setCursor(10,2);
lcd.print("N05:");
printTemperature(N05);
Serial.print(" ");
//delay(prodleva);
lcd.setCursor(0,3);
lcd.print("N10:");
printTemperature(N10);
Serial.print(" ");
// delay(prodleva);
lcd.setCursor(10,3);
lcd.print("N17:");
printTemperature(N17);
Serial.print(" ");
//Increment ID number
ID++;
