Hey guys. I am new here, so sorry if my question looks stupid but I really need some help. I am trying to use DS1302 RTC to make a clock (part of my project is to have real time clock). And the problem is that the time is absolutely wrong.
// Timur Maksiomv 2014
// A quick demo of how to use DS1302-library to make a quick
// clock using a DS1302 and a 16x2 LCD.
// I assume you know how to connect the DS1302 and LCD.
// DS1302: CE pin -> Arduino Digital 45
// I/O pin -> Arduino Digital 43
// SCLK pin -> Arduino Digital 41
// GND pin -> Arduino Digital 39
// VCC pin -> Arduino Digital 37
// LCD: DB7 -> Arduino Digital 7
// DB6 -> Arduino Digital 6
// DB5 -> Arduino Digital 5
// DB4 -> Arduino Digital 4
// E -> Arduino Digital 9
// RS -> Arduino Digital 8
#include <LiquidCrystal.h>
#include <DS1302RTC.h>
#include <Time.h>
// Init the DS1302
// Set pins: CE, IO,CLK
DS1302RTC RTC(45, 43, 41);
// Optional connection for RTC module
#define DS1302_GND_PIN 39
#define DS1302_VCC_PIN 37
// Init the LCD
// initialize the library with the numbers of the interface pins
// lcd(RS, E, d4, d5, d6, d7)
LiquidCrystal lcd(10, 8, 33, 31, 29, 27);
// Setup LCD to 16x2 characters
lcd.begin(16, 2);
// Activate RTC module
digitalWrite(DS1302_GND_PIN, LOW);
pinMode(DS1302_GND_PIN, OUTPUT);
digitalWrite(DS1302_VCC_PIN, HIGH);
pinMode(DS1302_VCC_PIN, OUTPUT);
lcd.print("RTC activated");
// Check clock oscillation
lcd.clear();
if (RTC.haltRTC())
lcd.print("Clock stopped!");
lcd.print("Clock working.");
// Check write-protection
lcd.setCursor(0,1);
if (RTC.writeEN())
lcd.print("Write allowed.");
lcd.print("Write protected.");
delay ( 2000 );
// Setup Time library
lcd.clear();
lcd.print("RTC Sync");
setSyncProvider(RTC.get); // the function to get the time from the RTC
if(timeStatus() == timeSet)
lcd.print(" Ok!");
lcd.print(" FAIL!");
delay ( 2000 );
lcd.clear();
// Display time centered on the upper line
lcd.setCursor(3, 0);
print2digits(hour());
lcd.print(" ");
print2digits(minute());
lcd.print(" ");
print2digits(second());
// Display abbreviated Day-of-Week in the lower left corner
lcd.setCursor(0, 1);
lcd.print(dayShortStr(weekday()));
// Display date in the lower right corner
lcd.setCursor(5, 1);
lcd.print(" ");
print2digits(day());
lcd.print("/");
print2digits(month());
lcd.print("/");
lcd.print(year());
// Warning!
if(timeStatus() != timeSet) {
lcd.print(F("RTC ERROR: SYNC!"));
delay ( 1000 ); // Wait approx 1 sec
void print2digits(int number) {
// Output leading zero
if (number >= 0 && number < 10) {
lcd.write('0');
lcd.print(number);
Can someone help me with solving the problem, so that DS1302 would sync time with my PC?
Now it shows 18/09/2013 23:34. It runs for 5 minutes (until 23:39) and then resets back to 23:34.
