I have 2 of the VMA301 RTC boards and they are both acting weird. These have the DS1302 chip on them. I did have them working at one point and I didn’t make any code changes. I tried the example code below the serial output and got the same results. I hope someone can help me figure it out because it’s driving me a little nuts! LOL
Here’s what I get from my Serial monitoring. I hope this helps:
16:07:51.942 -> getDOWStr: 000:00:00
16:07:51.942 -> getDateStr: 00/00/2000
16:07:51.942 -> getTimeStr: 00:00:00
16:07:53.981 -> getDOWStr: 000:00:00
16:07:53.981 -> getDateStr: 00/00/2000
16:07:53.981 -> getTimeStr: 00:00:00
16:07:56.038 -> getDOWStr: 000:00:00
16:07:56.038 -> getDateStr: 41/01/2004
16:07:56.038 -> getTimeStr: 00:00:00
16:07:58.082 -> getDOWStr: 100:00:00
16:07:58.082 -> getDateStr: 00/00/2000
16:07:58.082 -> getTimeStr: 00:00:00
16:08:00.130 -> getDOWStr: 000:00:00
16:08:00.130 -> getDateStr: 00/00/2000
16:08:00.130 -> getTimeStr: 00:00:00
16:08:02.184 -> getDOWStr: 000:00:00
16:08:02.184 -> getDateStr: 00/00/2000
16:08:02.184 -> getTimeStr: 00:00:00
16:08:04.216 -> getDOWStr: 000:00:00
16:08:04.216 -> getDateStr: 00/00/2000
16:08:04.250 -> getTimeStr: 00:00:00
16:08:06.286 -> getDOWStr: 000:00:00
16:08:06.286 -> getDateStr: 00/00/2000
16:08:06.286 -> getTimeStr: 00:00:00
16:08:08.334 -> getDOWStr: 000:00:00
16:08:08.334 -> getDateStr: 00/00/2000
16:08:08.334 -> getTimeStr: 00:00:00
16:08:10.367 -> getDOWStr: 000:00:00
16:08:10.367 -> getDateStr: 00/00/2000
16:08:10.367 -> getTimeStr: 00:00:00
16:08:12.426 -> getDOWStr: 000:00:00
16:08:12.426 -> getDateStr: 00/00/2000
16:08:12.426 -> getTimeStr: 00:00:00
16:08:14.474 -> getDOWStr: 000:00:00
16:08:14.474 -> getDateStr: 00/00/2000
16:08:14.474 -> getTimeStr: 00:00:00
16:08:16.515 -> getDOWStr: 000:00:00
16:08:16.515 -> getDateStr: 00/00/2000
16:08:16.515 -> getTimeStr: 00:00:00
16:08:18.576 -> getDOWStr: Tuesday
16:08:18.576 -> getDateStr: 03/02/2009
16:08:18.576 -> getTimeStr: 01:00:51
16:08:20.599 -> getDOWStr: Tuesday
16:08:20.633 -> getDateStr: 07/02/2009
16:08:20.633 -> getTimeStr: 01:00:19
16:08:22.646 -> getDOWStr: Tuesday
16:08:22.683 -> getDateStr: 07/02/2009
16:08:22.683 -> getTimeStr: 01:00:01
16:08:24.697 -> getDOWStr: Tuesday
16:08:24.731 -> getDateStr: 03/02/2009
16:08:24.731 -> getTimeStr: 01:00:03
16:08:26.771 -> getDOWStr: Saturday
16:08:26.771 -> getDateStr: 07/06/2019
16:08:26.771 -> getTimeStr: 15:44:45
16:08:28.810 -> getDOWStr: 715:44:45
16:08:28.810 -> getDateStr: 85/85/2165
16:08:28.810 -> getTimeStr: 27:85:85
// DS1302_LCD
// Copyright (C)2015 Rinky-Dink Electronics, Henning Karlsen. All right reserved
// web: http://www.RinkyDinkElectronics.com/
// A quick demo of how to use my DS1302-library to make a quick
// clock using a DS1302 and a 16x2 LCD.
// I assume you know how to connect the DS1302 and LCD.
// DS1302: CE pin -> Arduino Digital 2
// I/O pin -> Arduino Digital 3
// SCLK pin -> Arduino Digital 4
// LCD: DB7 -> Arduino Digital 6
// DB6 -> Arduino Digital 7
// DB5 -> Arduino Digital 8
// DB4 -> Arduino Digital 9
// E -> Arduino Digital 10
// RS -> Arduino Digital 11
#include <LiquidCrystal.h>
#include <DS1302.h>
// Init the DS1302
DS1302 rtc(32, 33, 34);
// Init the LCD
LiquidCrystal lcd(22, 23, 24, 25, 26, 27, 28);
// Set the clock to run-mode, and disable the write protection
rtc.halt(false);
rtc.writeProtect(false);
// Setup LCD to 16x2 characters
lcd.begin(20, 4);
// The following lines can be commented out to use the values already stored in the DS1302
rtc.setDOW(FRIDAY); // Set Day-of-Week to FRIDAY
rtc.setTime(12, 0, 0); // Set the time to 12:00:00 (24hr format)
rtc.setDate(6, 8, 2010); // Set the date to August 6th, 2010
// Display time centered on the upper line
lcd.setCursor(4, 0);
lcd.print(rtc.getTimeStr());
// Display abbreviated Day-of-Week in the lower left corner
lcd.setCursor(0, 1);
lcd.print(rtc.getDOWStr(FORMAT_SHORT));
// Display date in the lower right corner
lcd.setCursor(6, 1);
lcd.print(rtc.getDateStr());
// Wait one second before repeating :)
delay (1000);
