DS1302 RTC help
I’ve been trying to link the RTC module to the 1306 OLED. I have another program I used to test the OLED so I know it is all OK but when I run this code the OLED sticks on the ADAfruit logo and I cant see why??
// DS1302:  CE pin    -> Arduino Digital 27
//          I/O pin   -> Arduino Digital 29
//          SCLK pin  -> Arduino Digital 31
//          VCC pin   -> Arduino Digital 33
//          GND pin   -> Arduino Digital 35
#include <SPI.h>
#include <Wire.h>
#include <TimeLib.h>
#include <Time.h>
#include <DS1302RTC.h>
#include <Adafruit_SSD1306.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SPITFT.h>
#include <Adafruit_SPITFT_Macros.h>
#include <gfxfont.h>
   // If using software SPI (the default case):
  #define OLED_MOSI  11   //D1
  #define OLED_CLK   12   //D0
  #define OLED_DC    9
  #define OLED_CS    8
  #define OLED_RESET 10
Adafruit_SSD1306 display(OLED_MOSI, OLED_CLK, OLED_DC, OLED_RESET, OLED_CS);
// Init the DS1302
// Set pins:  CE, IO,CLK
 DS1302RTC RTC(27, 29, 31);
// Optional connection for RTC module
#define DS1302_GND_PIN 33
#define DS1302_VCC_PIN 35
    display.begin(SSD1306_SWITCHCAPVCC);
    display.display();
    delay(5000);
    display.clearDisplay();
    display.setTextSize(1);
    display.setCursor(0,0);
    display.print("Display test");
   // Activate RTC module
   digitalWrite(DS1302_GND_PIN, LOW);
   pinMode(DS1302_GND_PIN, OUTPUT);
   digitalWrite(DS1302_VCC_PIN, HIGH);
   pinMode(DS1302_VCC_PIN, OUTPUT);
   // Check clock oscillation
   if (RTC.haltRTC())
     display.print("Clock stopped!");
     display.print("Clock working.");
   // Check write-protection
   display.setCursor(0,1);
  if (RTC.writeEN())
    display.print("Write allowed.");
     display.print("Write protected.");
   delay ( 2000 );
   // Setup Time library
   display.print("RTC Sync");
   setSyncProvider(RTC.get); // the function to get the time from the RTC
   if(timeStatus() == timeSet)
     display.print(" Ok!");
     display.print(" FAIL!");
   delay ( 2000 );
   // Display time centered on the upper line
   display.setCursor(3, 0);
   print2digits(hour());
  display.print("  ");
   print2digits(minute());
   display.print("  ");
   print2digits(second());
   // Display abbreviated Day-of-Week in the lower left corner
   display.setCursor(0, 1);
   display.print(dayShortStr(weekday()));
   // Display date in the lower right corner
   display.setCursor(5, 1);
   display.print(" ");
   print2digits(day());
   display.print("/");
   print2digits(month());
   display.print("/");
   display.print(year());
   // Warning!
   if(timeStatus() != timeSet) {
     display.print(F("RTC ERROR: SYNC!"));
   delay ( 1000 ); // Wait approx 1 sec
void print2digits(int number) {
//   // Output leading zero
   if (number >= 0 && number < 10) {
     display.write('0');
   display.print(number);
Have you tested the RTC? Somewhere, somehow, someone has to set the time on the RTC. I don't see anything in your code that does that so any timing would kind of be left hanging as a discharged RTC running from a Unix epoch base would think it's midnight, January 1, 1970. Might take a while before 6 o'clock tonight kicks in.
Good point but my knowledge is limited as this is my first RTC project.
WIll see what I can find. Thanks for the pointer.
There are two built-in macros in the gcc compiler that return the host (PC) time when the code is compiled. They can be defined as,
const char DATE[12] = DATE;
const char TIME[9] = TIME;
and then parsed for values. DATE is yyyy-mm-dd, TIME is HH:mm:ss
You can add an adjustment of a couple seconds to account for compile/load time or tweak it later through some menu function.
