DS1302Z high current consumption
There was a problem with the DS1302Z chips. When the battery is connected to the VCC1 pin, current consumption reaches 0.1-0.5 mA and the clock starts immediately. With the DS1302 chips in the DIP-package, there are no such problems. What could be the reason?
Where are you measuring the current consumption ? between the back up battery and VCC1 or where ?
If the backup battery is being charged by the trickle charger via VCC2, then there may be a period of high current consumption until the backup battery is charged. You can turn off the trickle charger if you want.
Yes.
According to the datasheet, the trickle charger is disabled when the chip starts. In addition, we carry out a test without power to VCC2 and without any initialization of the chip.
