Yes and thankyou
here's my original code but with a pro mini and an LCD 4x20 that only 2x20 works?#!
(and it draws 150ma)
Problem 1. need it on the OLED
prob2. need to set the time like I used to or learn the new method?
//#include <SPI.h>
#include <Wire.h>
#define DS3231_I2C_ADDRESS 0x68
#include <LCD_I2C.h>
LCD_I2C lcd(0x27);
#include <SoftwareSerial.h>
// Create a software serial port!
//SoftwareSerial lcd = SoftwareSerial(0, 6);
//SoftwareSerial lcd(0, 6);
int x = 0;
Wire.begin(0x40);
//lcd.begin(9600);
lcd.begin(false); // Stop 2nd Wire.h call with (false) if multiple i2c devices
lcd.backlight();
// set the initial time here:
// DS3231 seconds, minutes, hours, day, date, month, year
//setDS3231time(00,22,3,1,15,8,22);
displayTime();
// lcd.setCursor(3,3);
// lcd.backlight();
lcd.clear();
delay(10);
//CLOCK
// Convert normal decimal numbers to binary coded decimal
byte decToBcd(byte val)
return ( (val / 10 * 16) + (val % 10) );
// Convert binary coded decimal to normal decimal numbers
byte bcdToDec(byte val)
return ( (val / 16 * 10) + (val % 16) );
void setDS3231time(byte second, byte minute, byte hour, byte dayOfWeek, byte
dayOfMonth, byte month, byte year)
// sets time and date data to DS3231
Wire.beginTransmission(DS3231_I2C_ADDRESS);
Wire.write(0); // set next input to start at the seconds register
Wire.write(decToBcd(second)); // set seconds
Wire.write(decToBcd(minute)); // set minutes
Wire.write(decToBcd(hour)); // set hours
Wire.write(decToBcd(dayOfWeek)); // set day of week (1=Sunday, 7=Saturday)
Wire.write(decToBcd(dayOfMonth)); // set date (1 to 31)
Wire.write(decToBcd(month)); // set month
Wire.write(decToBcd(year)); // set year (0 to 99)
Wire.endTransmission();
void readDS3231time(byte *second,
byte *minute,
byte *hour,
byte *dayOfWeek,
byte *dayOfMonth,
byte *month,
byte *year)
Wire.write(0); // set DS3231 register pointer to 00h
Wire.requestFrom(DS3231_I2C_ADDRESS, 7);
// request seven bytes of data from DS3231 starting from register 00h
*second = bcdToDec(Wire.read() & 0x7f);
*minute = bcdToDec(Wire.read());
*hour = bcdToDec(Wire.read() & 0x3f);
//hour = bcdToDec(Wire.read() & 0x3f);
*dayOfWeek = bcdToDec(Wire.read());
*dayOfMonth = bcdToDec(Wire.read());
*month = bcdToDec(Wire.read());
*year = bcdToDec(Wire.read());
void displayTime()
byte second, minute, hour, dayOfWeek, dayOfMonth, month, year;
// retrieve data from DS3231
readDS3231time(&second, &minute, &hour, &dayOfWeek, &dayOfMonth, &month,
&year);
// send it to the serial monitor
Serial.print(hour, DEC);
//lcd.print(hour);
// convert the byte variable to a decimal number when displayed
Serial.print(":");
if (minute < 10)
Serial.print("0");
Serial.print(minute, DEC);
Serial.print(":");
if (second < 10)
Serial.print("0");
Serial.print(second, DEC);
Serial.print(" ");
Serial.print(dayOfMonth, DEC);
Serial.print("/");
Serial.print(month, DEC);
Serial.print("/");
Serial.print(year, DEC);
Serial.print(" Day of week: ");
lcd.write(0xFE); lcd.write(0x58); delay(10); //cls
lcd.print(hour); lcd.print(":");
if (minute < 10)
lcd.print("0");
lcd.print(minute); lcd.print(":");
if (second < 10)
lcd.print("0");
lcd.print(second);
switch (dayOfWeek) {
case 1:
Serial.println("Sunday");
case 2:
Serial.println("Monday");
case 3:
Serial.println("Tuesday");
case 4:
Serial.println("Wednesday");
case 5:
Serial.println("Thursday");
case 6:
Serial.println("Friday");
case 7:
Serial.println("Saturday");
