I have managed to add couple of buttons to adjust time on DS1307.
Problem is that I can display adjusted time only, after adjustments are done time just keeps displaying same and it looks like the script is not pulling time from DS1307.
Can someone help with below script? I am very new at this. I think problem is that I am doing:
#define DS1307 B1101000
-and- - RTC_DS1307 RTC;
I just don't know how to separate (or combine) these 2.
#include <Wire.h>
#include <RTClib.h>
// I2C address
RTC_DS1307 RTC;
// pinout for the 7 segment display
// Starts top center, clock-wise, then
// center line, then dot
byte segment[] = {
3, 2, 5, 6, 7, 8, 9, 4
byte second = 0, minute = 0, hour = 0;
int led1 = 3;
int led2 = 2;
int led3 = 5;
int led4 = 4;
int led5 = 6;
int led6 = 7;
int led7 = 8;
int led8 = 9;
//************Button*****************//
int P1 = 11; // SET HOURS
int P2 = 12; // SET MINUTES
//************Variables**************//
int hourupg;
int minupg;
int menu = 0;
void updatetime();
void printtime();
void print7digit(byte number);
byte DECTOBCD(byte val);
byte BCDTODEC(byte val);
byte i;
Wire.begin();
pinMode(led1, OUTPUT);
pinMode(led2, OUTPUT);
pinMode(led3, OUTPUT);
pinMode(led4, OUTPUT);
pinMode(led5, OUTPUT);
pinMode(led6, OUTPUT);
pinMode(led7, OUTPUT);
pinMode(led8, OUTPUT);
for (i = 0; i < 8; i++) {
pinMode(segment[i], OUTPUT);
digitalWrite(segment[i], LOW);
pinMode(P1, INPUT);
pinMode(P2, INPUT);
Wire.begin();
RTC.begin();
if (! RTC.isrunning()) {
RTC.adjust(DateTime(__DATE__, __TIME__));
// RTC.adjust(DateTime(__DATE__, __TIME__)); //removing "//" to adjust the time
// The default display shows the date and time
int menu = 0;
updatetime();
printtime();
// check if you press the SET button and increase the menu index
if (digitalRead(P1))
DisplaySetHour();
else if (digitalRead(P2))
DisplaySetMinute();
StoreAgg();
delay(100);
menu = 0;
// Pull current time off the DS1307
void updatetime() {
Wire.beginTransmission(DS1307);
Wire.write(0x00);
Wire.endTransmission();
Wire.requestFrom(DS1307, 3);
// Don't actually use seconds value. Feel free to.
second = BCDTODEC(Wire.read() & 0x7f);
minute = BCDTODEC(Wire.read());
hour = BCDTODEC(Wire.read() & 0x3f);
void DisplaySetHour()
// Hour setting
DateTime now = RTC.now();
if (digitalRead(P1) == HIGH)
if (hourupg == 23)
hourupg = 0;
hourupg = hourupg + 1;
digitalWrite(led2, HIGH); // LETTER H FOR SETTING HOURS
digitalWrite(led3, HIGH);
digitalWrite(led7, HIGH);
digitalWrite(led6, HIGH);
digitalWrite(led8, HIGH);
digitalWrite(led2, LOW);
digitalWrite(led3, LOW);
digitalWrite(led7, LOW);
digitalWrite(led6, LOW);
digitalWrite(led8, LOW);
void DisplaySetMinute()
// Minute setting
if (digitalRead(P2) == HIGH)
if (minupg == 59)
minupg = 0;
minupg = minupg + 1;
digitalWrite(led1, HIGH); // LETTER F FOR SETTING MINUTES
digitalWrite(led1, LOW);
void StoreAgg()
// Variable saving
RTC.adjust(DateTime(19, 6, 6, hourupg, minupg, 0));
delay(200);
// Flash each digit of the time in turn on the 7 segment
void printtime() {
byte j;
// Convert from 24 hour to 12 hour mode
// Should be done on the DS1307. I'm sorry.
byte temphour = hour % 12;
if (temphour == 0) {
// Not zero based, not one based, but 12 based.
temphour = 12;
// Only display highest digit if it's nonzero
if (temphour > 9) {
print7digit(temphour / 10);
delay(500); // Repeated magic values in my code? Never!
for (j = 0; j < 8; j++) {
digitalWrite(segment[j], LOW);
delay(150);
print7digit(temphour % 10);
// Light the dot on last hour digit
digitalWrite(segment[7], HIGH);
print7digit(minute / 10);
delay(150);
print7digit(minute % 10);
delay(2000);
// Display a single digit on the 7 segment
void print7digit(byte number) {
// Bitfield for digits 0-9
const byte numtable[] = {
B00111111,
B00000110,
B01011011,
B01001111,
B01100110,
B01101101,
B01111101,
B00000111,
B01111111,
B01100111
byte litpins = numtable[number];
byte i;
digitalWrite(segment[i], (litpins >> i) & 1);
byte DECTOBCD(byte val) {
return ((val / 10) << 4) + (val % 10);
byte BCDTODEC(byte val) {
return (val >> 4) * 10 + (val & 0xf);
