Here's the problem, I wire it up, i supply 5v and the battery rail with 3.3v to cover the lithium battery incase
you do not have one, i connect the sda and scl lines up... it fails everytime, i use 5v resistor pull ups, i do
everything ...
lol larry, i thought that too, and used a flat screwdriver just to prise it open a bit..
I see a diode, is that a zener? 5v too much? lower voltage is the only thing i've not tried, but take a look at the breakout board
which arrived today the one with the 5 pins, they have all the pull up resistors, and yet it fails.
voltage 1 pin shows 3v (battery)
voltage 2 pin, was 0, so I hooked up 5v to pwr2
surely not have to give the "pullup" resistors on this board "pullup" resistors!?
I have no documentation on this breakout, so i figured IO had to be either SDA OR SCL likewise for Sclck? Serial Clock, rst pin, i did not use it? maybe I should be?...
* Read and set through serial port demo sketch for DS1307 I2C rtc clock
* DS1307 library provided by mattt & D.Sjunnesson, corrected by bricofoy.
* See DS1307.h for more details.
* This exemple code is under GNU GPL
* (c) bricofoy 2012
// This is for compatibility with both arduino 1.0 and previous versions
#if defined(ARDUINO) && ARDUINO >= 100
#include "Arduino.h"
#else
#include "WProgram.h"
#endif
#include <Wire.h>
#include <DS1307.h>
use();
read_RTC();
// use explanation message
void use() {
Serial.println("\nUSE : u U r R h[00-23]m[00-59]s[00-59]j0[1-7]D[01-31]M[01-12]A[00-49]");
Serial.println("\nEXEMPLE : h09m35d03 set time to 09h35 and day of week 3 (thuesday).");
Serial.println("\nCommands : h** : hour, m** : minutes, s** : seconds, d0* : day of week");
Serial.println(" M** : month, Y** : year, D** : day of month.");
Serial.println(" r stops clock, R starts it. ");
Serial.println(" u or U shows this message, all other caracter shows time.");
// DS1307 time read function
void read_RTC() {
Serial.print("\nActual time : ");
Serial.print(RTC.get(DS1307_HR,true)); //read the hour and also update all the values by pushing in true
Serial.print(":");
Serial.print(RTC.get(DS1307_MIN,false));//read minutes without update (false)
Serial.print(":");
Serial.print(RTC.get(DS1307_SEC,false));//read seconds
Serial.print(" "); // some space for a more happy life
Serial.print(RTC.get(DS1307_DOW,false));
Serial.print(" ");
Serial.print(RTC.get(DS1307_DATE,false));//read date
Serial.print("/");
Serial.print(RTC.get(DS1307_MTH,false));//read month
Serial.print("/");
Serial.println(RTC.get(DS1307_YR,false)); //read year
// set clock values
void write_RTC() {
char value=0;
char command=0;
command = Serial.read();
delay(50); //delay to allow good serial port reading
value=byte((Serial.read()-48)*10); //-48 becaus ASCII value for 0 is 48, 1 is 49, etc and *10 because we read tens first
delay(50);
value+=byte((Serial.read()-48)); //and then we read units
switch (command) {
case 'h' :
RTC.set(DS1307_HR,value);
Serial.print("hours set to ");
Serial.println(value,DEC);
case 'm' :
RTC.set(DS1307_MIN,value);
Serial.print("minutes set to ");
case 's' :
RTC.set(DS1307_SEC,value);
Serial.print("seconds set to ");
case 'D' :
RTC.set(DS1307_DATE,value);
Serial.print("day of month set to ");
case 'd' :
RTC.set(DS1307_DOW,value);
Serial.print("day of week set to ");
case 'M' :
RTC.set(DS1307_MTH,value);
Serial.print("month set to ");
case 'Y' :
RTC.set(DS1307_YR,value);
Serial.print("year set to ");
case 'u' :
case 'U' :
use();
case 'r' :
RTC.stop();
Serial.println("Clock stopped");
case 'R' :
RTC.start();
Serial.println("Clock running");
default :
read_RTC();
if (Serial.available()) {
write_RTC();
as I say, this code works fine with the boards with the ram on, frustrating.
