DS1307 can not read and write time in arduino.
hello everyone
In mid-November, I have designed a shield based on arduino.I have to debug a week.However, it does not work.The OLED display and bluetooth is ok.
Here is my sch
Here is my pcb
You can see in my schematic,I use IIC to connects two devices,they are not wroking properly.First, I tested the DS1307.I found the DS1307 has no answer.
Here is my code base on arduino.
#include <Wire.h>
int clockAddress = 0x68;  // This is the I2C address
int command = 0;  // This is the command char, in ascii form, sent from the serial port
long previousMillis = 0;  // will store last time Temp was updated
byte second, minute, hour, dayOfWeek, dayOfMonth, month, year;
byte test;
// Convert normal decimal numbers to binary coded decimal
byte decToBcd(byte val)
  return ( (val/10*16) + (val%10) );
// Convert binary coded decimal to normal decimal numbers
byte bcdToDec(byte val)
  return ( (val/16*10) + (val%16) );
// 1) Sets the date and time on the ds1307
// 2) Starts the clock
// 3) Sets hour mode to 24 hour clock
// Assumes you're passing in valid numbers,
// Probably need to put in checks for valid numbers.
void setDateDs1307()
  // Use of (byte) type casting and ascii math to achieve result.
 second = (byte) ((Serial.read() - 48) * 10 + (Serial.read() - 48));
  minute = (byte) ((Serial.read() - 48) *10 +  (Serial.read() - 48));
  hour  = (byte) ((Serial.read() - 48) *10 +  (Serial.read() - 48));
  dayOfWeek = (byte) (Serial.read() - 48);
  dayOfMonth = (byte) ((Serial.read() - 48) *10 +  (Serial.read() - 48));
  month = (byte) ((Serial.read() - 48) *10 +  (Serial.read() - 48));
  year= (byte) ((Serial.read() - 48) *10 +  (Serial.read() - 48));
  /*second = 50;
  minute = 56;
  hour  = 9;
  dayOfWeek = 2;
  dayOfMonth = 2;
  month = 12;
  year= 14;*/
  Wire.beginTransmission(clockAddress);
  Wire.write(byte(0x00));
  Wire.write(decToBcd(second));  // 0 to bit 7 starts the clock
  Wire.write(decToBcd(minute));
  Wire.write(decToBcd(hour));    // If you want 12 hour am/pm you need to set
  // bit 6 (also need to change readDateDs1307)
  Wire.write(decToBcd(dayOfWeek));
  Wire.write(decToBcd(dayOfMonth));
  Wire.write(decToBcd(month));
  Wire.write(decToBcd(year));
  Wire.endTransmission();
// Gets the date and time from the ds1307 and prints result
void getDateDs1307() {
  // Reset the register pointer
  Wire.requestFrom(clockAddress, 7);
  // A few of these need masks because certain bits are control bits
  second     = bcdToDec(Wire.read() & 0x7f);
  minute     = bcdToDec(Wire.read());
  // Need to change this if 12 hour am/pm
  hour       = bcdToDec(Wire.read() & 0x3f);
  dayOfWeek  = bcdToDec(Wire.read());
  dayOfMonth = bcdToDec(Wire.read());
  month      = bcdToDec(Wire.read());
  year       = bcdToDec(Wire.read());
  Serial.print(hour, DEC);
  Serial.print(":");
  Serial.print(minute, DEC);
  Serial.print(":");
  Serial.print(second, DEC);
  Serial.print("  ");
  Serial.print(month, DEC);
  Serial.print("/");
  Serial.print(dayOfMonth, DEC);
  Serial.print("/");
  Serial.print(year, DEC);
  Wire.begin();
  Serial.begin(57600);
  if (Serial.available()) {  // Look for char in serial que and process if found
    command = Serial.read();
    if (command == 84) {      //If command = "T" Set Date
      setDateDs1307();
      getDateDs1307();
      Serial.println(" ");
    else if (command == 81) {  //If command = "Q" RTC1307 Memory Functions
      delay(100);
        // If command = "1" RTC1307 Initialize Memory - All Data will be set to 255 (0xff).
        // Therefore 255 or 0 will be an invalid value.
        if (command == 49) {
          // 255 will be the init value and 0 will be cosidered an error that
          // occurs when the RTC is in Battery mode.
          // Set the register pointer to be just past the date/time registers.
          Wire.write(byte(0x08));
          for (int i = 1; i <= 27; i++) {
            Wire.write(byte(0xff));
            delay(100);
          getDateDs1307();
          Serial.println(": RTC1307 Initialized Memory");
        else if (command == 50) {      //If command = "2" RTC1307 Memory Dump
          getDateDs1307();
          Serial.println(": RTC 1307 Dump Begin");
          Wire.requestFrom(clockAddress, 64);
          for (int i = 1; i <= 64; i++) {
            test = Wire.read();
            Serial.print(i);
            Serial.print(":");
            Serial.println(test, DEC);
          Serial.println(" RTC1307 Dump end");
    Serial.print("Command: ");
    Serial.println(command);  // Echo command CHAR in ascii that was sent
  command = 0;  // reset command
  delay(100);
Time is always parked in the 45:85:85,I know this is the wrong data.I use two leonardo to test.Unfortunately, I still did not get the correct data.Then,I suspect that the IIC on my leonardo is broken.
I've used other IIC devices, I put GY-30 connected to leonardo, and the code I‘ve been used,it can't work.I borrowed a Duemilanove from others.The GY-30 can work,and the DS1307 in my shield doesn't work.Now I have no idea.anyone can help me,and anyone can upload code about DS1307 base on arduino,In order to confirm the problem in my code or on my PCB.
Thanks
Have you run the I2C scanner from the Arduino playground ?
An if the DS1307 doesnt respond.. either its defective or you have an error in your design or manufacturing
I assume you have used a continuity tester to confirm the connections to the DS1307?
Did it work ok on your prototype?- I'm assuming you did a breadboard exercise first.
