I tried to show the time and date in arduino with RTC 1307, but after I turn off the power and turn it on again the next day, hour and date don’t update, i’m confused why such as … there is sample code I used to try:
/ This is for compatibility with both arduino 1.0 and previous versions
#if defined(ARDUINO) && ARDUINO >= 100
#include "Arduino.h"
#else
#include "WProgram.h"
#endif
#include <Wire.h>
#include <DS1307.h> // written by mattt on the Arduino forum and modified by D. Sjunnesson
RTC.stop();
RTC.set(DS1307_SEC,1); //set the seconds
RTC.set(DS1307_MIN,23); //set the minutes
RTC.set(DS1307_HR,12); //set the hours
RTC.set(DS1307_DOW,4); //set the day of the week
RTC.set(DS1307_DATE,5); //set the date
RTC.set(DS1307_MTH,3); //set the month
RTC.set(DS1307_YR,9); //set the year
RTC.start();
Serial.print(RTC.get(DS1307_HR,true)); //read the hour and also update all the values by pushing in true
Serial.print(":");
Serial.print(RTC.get(DS1307_MIN,false));//read minutes without update (false)
Serial.print(":");
Serial.print(RTC.get(DS1307_SEC,false));//read seconds
Serial.print(" "); // some space for a more happy life
Serial.print(RTC.get(DS1307_DATE,false));//read date
Serial.print("/");
Serial.print(RTC.get(DS1307_MTH,false));//read month
Serial.print("/");
Serial.print(RTC.get(DS1307_YR,false)); //read year
please help me…
Are you saying that when you set the RTC to March 5th, 2009 12:23:01 in setup() that the time gets reset to March 5th, 2009 12:23:01 each time you turn on the power? Isn't that what you are telling it to do?
Perhaps you should only set the RTC chip once and after that just read the time.
Two codes
one to set
//Arduino 1.0+ Only
//Arduino 1.0+ Only
// pre-set the time in the void then use reset button to set it!
#include <LiquidCrystal.h>
#include "Wire.h"
#define DS1307_ADDRESS 0x68
byte zero = 0x00; //workaround for issue #527
LiquidCrystal lcd(8,9,16,5,6,7);
void setup(){
Wire.begin();
lcd.begin(16, 2);
lcd.clear();
setDateTime(); //MUST CONFIGURE IN FUNCTION
printDate();
Serial.println("loopstart");
void loop(){
lcd.clear();
printDate();
void setDateTime(){
byte second = 30; //0-59
byte minute = 24; //0-59
byte hour = 0; //0-23
byte weekDay = 5; //1-7
byte monthDay = 19; //1-31
byte month = 4; //1-12
byte year = 13; //0-99
Wire.beginTransmission(DS1307_ADDRESS);
Wire.write(zero); //stop Oscillator
Wire.write(decToBcd(second));
Wire.write(decToBcd(minute));
Wire.write(decToBcd(hour));
Wire.write(decToBcd(weekDay));
Wire.write(decToBcd(monthDay));
Wire.write(decToBcd(month));
Wire.write(decToBcd(year));
Wire.write(zero); //start
Wire.endTransmission();
byte decToBcd(byte val){
// Convert normal decimal numbers to binary coded decimal
return ( (val/10*16) + (val%10) );
byte bcdToDec(byte val) {
// Convert binary coded decimal to normal decimal numbers
return ( (val/16*10) + (val%16) );
void printDate(){
// Reset the register pointer
Wire.write(zero);
Wire.requestFrom(DS1307_ADDRESS, 7);
int second = bcdToDec(Wire.read());
int minute = bcdToDec(Wire.read());
int hour = bcdToDec(Wire.read() & 0b111111); //24 hour time
int weekDay = bcdToDec(Wire.read()); //0-6 -> sunday - Saturday
int monthDay = bcdToDec(Wire.read());
int month = bcdToDec(Wire.read());
int year = bcdToDec(Wire.read());
//print the date EG 3/1/11 23:59:59
Serial.print(month);
Serial.print("/");
Serial.print(monthDay);
Serial.print("/");
Serial.print(year);
Serial.print(" ");
Serial.print(hour);
Serial.print(":");
Serial.print(minute);
Serial.print(":");
Serial.println(second);
lcd.print(monthDay);
lcd.print("/");
lcd.print(month);
lcd.print("/");
lcd.print(year);
lcd.setCursor(0,1);
lcd.print(hour);
lcd.print(":");
lcd.print(minute);
lcd.print(":");
if(second <10)
lcd.print("0");
lcd.print(second);
The other to run
//Arduino 1.0+ Only
//Arduino 1.0+ Only
#include "Wire.h"
// set the LCD address to 0x27 for a 20 chars 4 line display
LiquidCrystal_I2C lcd(0x27,20,4);
void setup(){
Wire.begin();
lcd.init(); // initialize the lcd
// Print our characters on the LCD
lcd.backlight(); //Backlight ON if under program control
lcd.setCursor(0,0); //Start at character 3 on line 0
// Print a message to the LCD.
lcd.print("Today it is ");
void loop(){
printDate();
void printDate(){
byte zero = 0x00;
Wire.write(zero);
lcd.setCursor(12, 0);
switch (weekDay) // Friendly printout the weekday
case 1:
lcd.print("MON ");
Serial.print("MON ");
case 2:
lcd.print("TUE ");
Serial.print("TUE ");
case 3:
lcd.print("WED ");
Serial.print("WED ");
case 4:
lcd.print("THU ");
Serial.print("THU ");
case 5:
lcd.print("FRI ");
Serial.print("FRI ");
case 6:
lcd.print("SAT ");
Serial.print("SAT ");
case 7:
lcd.print("SUN ");
Serial.print("SUN ");
Serial.print("/");
Serial.print("/");
Serial.print(year);
Serial.print(" ");
Serial.print(hour);
Serial.print(":");
Serial.print(":");
lcd.setCursor(0,1);
lcd.print("/");
lcd.print(month);
lcd.print("/");
lcd.print(year);
lcd.print(" ");
lcd.print(hour);
lcd.print(":");
lcd.print(minute);
lcd.print(":");
if(second <10)
lcd.print("0");
lcd.print(second);
All you need…
That’s good thinking Nick…
John's pointing out to you, that every time you run the sketch, these lines reset the time and date back to where it was originally...
RTC.stop();
RTC.start();
Nick's suggestion is to have one sketch to set the time and date (and theoretically never have to run it again) and another sketch to use the clock.
