I'm trying to understand how the 'T' in the following lines of code equates to 84. Or rather, what does the 84 mean? Thanks for the help in advance. I'm trying to learn.
Wire.begin();
Serial.begin(57600);
if (Serial.available()) { // Look for char in serial que and process if found
command = Serial.read();
if (command == 84) { //If command = "T" Set Date
setDateDs1307();
getDateDs1307();
Serial.println(" ");
else if (command == 81) { //If command = "Q" RTC1307 Memory Functions
Can someone provide some guidance? what does the following lines of code mean?.......for (i = 1; i <= 64; i++).........is it saying___ (if I=1 I is less than 64 Increase i)? Is this for Arduino memor or DS1307?
else if (command == 50)
{ //If command = "2" RTC1307 Memory Dump
getDateDs1307();
Serial.println(": RTC 1307 Dump Begin");
Wire.beginTransmission(DS1307_I2C_ADDRESS);
Wire.send(0x00);
Wire.endTransmission();
Wire.requestFrom(DS1307_I2C_ADDRESS, 64);
Set variable i to equal 1.
continue to loop while variable i is less than or equal to 64
each iteration of the loop, increment variable i to equal the value of variable i + 1.
