ds1307 RGB led day night cycle
Hi, i would really appreciate any help with my project!
I have an arduino uno, ds1307, and a rgb led strip, all running fine independently. After various help from other users on this forum, I have come up with this setup.
What I'm aiming for is to fade these colour spectrums throughout the day and night, each one lasting different lengths of time, depending on their function.
These are the colours i want to fade through (with the colour set function i used to test the colours)
setColor(243,233,229); //dawn pink
setColor(245,68,0); //dawn orange
setColor(238,165,130); //dawn yellow
setColor(255,250,244); //carbon arc
setColor(255,255,255); //sun
setColor(255,255,251); // high noon
setColor(255,255,255); // sun
setColor(250,214,165); //dusk orange
setColor(38,83,141); //dusk blue
setColor(0,85,165); //moonlight blue
setColor(25,25,112); //midnight blue
setColor(0,0,0); //night
and here is the code i have so far without the colour spectrum added
int redPin = 9;
int greenPin = 10;
int bluePin = 11;
// Date and time functions using a DS1307 RTC connected via I2C and Wire lib
#include <Wire.h>
#include "RTClib.h"
RTC_DS1307 rtc;
void setup () {
  Serial.begin(57600);
#ifdef AVR
  Wire.begin();
#else
  Wire1.begin(); // Shield I2C pins connect to alt I2C bus on Arduino Due
#endif
  rtc.begin();
  if (! rtc.isrunning()) {
    Serial.println("RTC is NOT running!");
    // following line sets the RTC to the date & time this sketch was compiled
    rtc.adjust(DateTime(__DATE__, __TIME__));
    pinMode (redPin, OUTPUT);
    pinMode (greenPin,OUTPUT);
    pinMode(bluePin,OUTPUT);
void loop () {
  DateTime now = rtc.now();
  Serial.print(now.year(), DEC);
  Serial.print('/');
  Serial.print(now.month(), DEC);
  Serial.print('/');
  Serial.print(now.day(), DEC);
  Serial.print(' ');
  Serial.print(now.hour(), DEC);
  Serial.print(':');
  Serial.print(now.minute(), DEC);
  Serial.print(':');
  Serial.print(now.second(), DEC);
  Serial.print(" since midnight 1/1/1970 = ");
  Serial.print(now.unixtime());
  Serial.print("s = ");
  Serial.print(now.unixtime() / 86400L);
  Serial.println("d");
  // calculate a date which is 7 days and 30 seconds into the future
  DateTime future (now.unixtime() + 7 * 86400L + 30);
  Serial.print(" now + 7d + 30s: ");
  Serial.print(future.year(), DEC);
  Serial.print('/');
  Serial.print(future.month(), DEC);
  Serial.print('/');
  Serial.print(future.day(), DEC);
  Serial.print(' ');
  Serial.print(future.hour(), DEC);
  Serial.print(':');
  Serial.print(future.minute(), DEC);
  Serial.print(':');
  Serial.print(future.second(), DEC);
void setColor(int red, int green, int blue)
#ifdef COMMON_ANODE
  red = 255 - red;
  green = 255 - green;
  blue = 255 - blue;
#endif
  analogWrite(redPin, red);
  analogWrite(greenPin, green);
  analogWrite(bluePin, blue);
What I'm asking is, what functions do i need to add to easily get the colours to slowly fade through the spectrum, and how do i set the time for each one to start?
Thanks for any help! it is much appreciated!
Tom
You will need a color interpolation function. The function takes two colors and a percentage as parameters and returns the color that is the given percentage between the two. The function generates the color by interpolating the individual RGB components.
Thanks, I've had a quick google, and all i can seem to find is various code, but no tutorial of how to understand it. i have also tried the arduino page on crossFade, and entered my colour requirements and all I'm getting is a random selection between green and blue. :confused:
We can't see that code. Therefore, all we can do is assume that you wrote it incorrectly.
My apologies, forgot to stick it in, in a rush.
the code is bellow, i just added the colours i wanted from the code here:
my code:
// Output
int redPin = 9;   // Red LED,   connected to digital pin 9
int grnPin = 10;  // Green LED, connected to digital pin 10
int bluPin = 11;  // Blue LED,  connected to digital pin 11
// Color arrays
int black[3]  = { 0, 0, 0 };
int dawnone[3] = {243,233,229};
int dawntwo[3]    = { 245, 68, 0 };
int dawnthree[3]  = { 238, 165, 130 };
int carbonarc[3]   = { 255, 250, 255 };
int sun[3] = { 255, 255, 255 };
int noon[3] = { 255, 255, 251 };
int duskone[3] = {250,214,165};
int dusktwo[3] = {38,83,141};
int blueone[3] = {0,85,156};
int bluetwo[3] = {25,25,112};
// etc.
// Set initial color
int redVal = black[0];
int grnVal = black[1];
int bluVal = black[2];
int wait = 5;      // 10ms internal crossFade delay; increase for slower fades
int hold = 0;       // Optional hold when a color is complete, before the next crossFade
int DEBUG = 1;      // DEBUG counter; if set to 1, will write values back via serial
int loopCount = 60; // How often should DEBUG report?
int repeat = 3;     // How many times should we loop before stopping? (0 for no stop)
int j = 0;          // Loop counter for repeat
// Initialize color variables
int prevR = redVal;
int prevG = grnVal;
int prevB = bluVal;
// Set up the LED outputs
  pinMode(redPin, OUTPUT);   // sets the pins as output
  pinMode(grnPin, OUTPUT);
  pinMode(bluPin, OUTPUT);
  if (DEBUG) {           // If we want to see values for debugging...
    Serial.begin(9600);  // ...set up the serial ouput
// Main program: list the order of crossfades
  crossFade(dawnone);
  crossFade(dawntwo);
  crossFade(dawnthree);
  crossFade(carbonarc);
  crossFade(sun);
  crossFade(noon);
  crossFade(sun);
  crossFade(duskone);
  crossFade(dusktwo);
  crossFade(blueone);
  crossFade(bluetwo);
  crossFade(black);
  if (repeat) { // Do we loop a finite number of times?
    j += 1;
    if (j >= repeat) { // Are we there yet?
      exit(j);         // If so, stop.
/* BELOW THIS LINE IS THE MATH -- YOU SHOULDN'T NEED TO CHANGE THIS FOR THE BASICS
* The program works like this:
* Imagine a crossfade that moves the red LED from 0-10,
*   the green from 0-5, and the blue from 10 to 7, in
*   ten steps.
*   We'd want to count the 10 steps and increase or
*   decrease color values in evenly stepped increments.
*   Imagine a + indicates raising a value by 1, and a -
*   equals lowering it. Our 10 step fade would look like:
*   1 2 3 4 5 6 7 8 9 10
* R + + + + + + + + + +
* G   +   +   +   +   +
* B     -     -     -
* The red rises from 0 to 10 in ten steps, the green from
* 0-5 in 5 steps, and the blue falls from 10 to 7 in three steps.
* In the real program, the color percentages are converted to
* 0-255 values, and there are 1020 steps (255*4).
* To figure out how big a step there should be between one up- or
* down-tick of one of the LED values, we call calculateStep(),
* which calculates the absolute gap between the start and end values,
* and then divides that gap by 1020 to determine the size of the step
* between adjustments in the value.
int calculateStep(int prevValue, int endValue) {
  int step = endValue - prevValue; // What's the overall gap?
  if (step) {                      // If its non-zero,
    step = 1020/step;              //   divide by 1020
  return step;
/* The next function is calculateVal. When the loop value, i,
*  reaches the step size appropriate for one of the
*  colors, it increases or decreases the value of that color by 1.
*  (R, G, and B are each calculated separately.)
int calculateVal(int step, int val, int i) {
  if ((step) && i % step == 0) { // If step is non-zero and its time to change a value,
    if (step > 0) {              //   increment the value if step is positive...
      val += 1;
    else if (step < 0) {         //   ...or decrement it if step is negative
      val -= 1;
  // Defensive driving: make sure val stays in the range 0-255
  if (val > 255) {
    val = 255;
  else if (val < 0) {
    val = 0;
  return val;
/* crossFade() converts the percentage colors to a
*  0-255 range, then loops 1020 times, checking to see if
*  the value needs to be updated each time, then writing
*  the color values to the correct pins.
void crossFade(int color[3]) {
  // Convert to 0-255
  int R = (color[0] * 255) / 100;
  int G = (color[1] * 255) / 100;
  int B = (color[2] * 255) / 100;
  int stepR = calculateStep(prevR, R);
  int stepG = calculateStep(prevG, G);
  int stepB = calculateStep(prevB, B);
  for (int i = 0; i <= 1020; i++) {
    redVal = calculateVal(stepR, redVal, i);
    grnVal = calculateVal(stepG, grnVal, i);
    bluVal = calculateVal(stepB, bluVal, i);
    analogWrite(redPin, redVal);   // Write current values to LED pins
    analogWrite(grnPin, grnVal);
    analogWrite(bluPin, bluVal);
    delay(wait); // Pause for 'wait' milliseconds before resuming the loop
    if (DEBUG) { // If we want serial output, print it at the
      if (i == 0 or i % loopCount == 0) { // beginning, and every loopCount times
        Serial.print("Loop/RGB: #");
        Serial.print(i);
        Serial.print(" | ");
        Serial.print(redVal);
        Serial.print(" / ");
        Serial.print(grnVal);
        Serial.println(bluVal);
      DEBUG += 1;
  // Update current values for next loop
  prevR = redVal;
  prevG = grnVal;
  prevB = bluVal;
  delay(hold); // Pause for optional 'wait' milliseconds before resuming the loop
ignore my ignorance! just realised that code adjusts the brightness into percentages in that code, not the 255 stages!
thanks for the help so far, you can ignore the last few of my posts. here is the code I'm using, now working properly. So the next think I'm after help wise is setting each section of the fade cycle to come on at a particular time, and hold it until the next one starts. code so far below, i haven't added the #include<wire.h> section yet. could i copy the fade code bellow to the RTC code to get started, and set it that way?
thanks
// Output
// Color arrays
int dawnone[3] = {98,90,70};
int dawntwo[3]    = { 95, 40, 0 };
int dawnthree[3]  = { 88, 57, 30 };
int carbonarc[3]   = { 100, 97, 100 };
int sun[3] = { 100, 100, 100 };
int noon[3] = { 100, 100, 97 };
int duskone[3] = {97,85,56};
int dusktwo[3] = {20,40,78};
int blueone[3] = {0,30,70};
int bluetwo[3] = {10,10,70};
// etc.
int hold = 30;       // Optional hold when a color is complete, before the next crossFade
int repeat = 0;     // How many times should we loop before stopping? (0 for no stop)
int prevR = redVal;
int prevG = grnVal;
int prevB = bluVal;
  crossFade(dawntwo);
  crossFade(dawnone);
  crossFade(sun);
  crossFade(noon);
  crossFade(sun);
  crossFade(duskone);
  crossFade(black);
  crossFade(dusktwo);
  crossFade(blueone);
  crossFade(bluetwo);
  crossFade(black);
    j += 1;
*   ten steps.
* G   +   +   +   +   +
* B     -     -     -
  return step;
      val += 1;
      val -= 1;
  if (val > 255) {
    val = 255;
  else if (val < 0) {
    val = 0;
  return val;
  // Convert to 0-255
        Serial.print(i);
      DEBUG += 1;
  prevR = redVal;
  prevG = grnVal;
  prevB = bluVal;
How is the Arduino supposed to know what time it is?
I have a ds1307 rtc sheild running with the arduino. I have it set up with the right time and date, the only bit I am unsure of now is how to start coding the arduino to start each function at a specific time.
I'll ask the same question I usually ask, then. How would YOU start a function at a specific time? You have to know what time to start the function. (I don't see anything like that in your code.) You have to know what time it is now. (I don't see any indication that you have an RTC in your code. Specifically, there is nothing that gets the time.) You have to decide if now is the right time, using some if statement(s). If it is, do it. If not, maybe it will be the right time later, so back to watching TV and drinking beer.
thanks for your guidance so far, i have this code now, I'm not sure if its going in the right direction, but i keep getting the error '
core.a(main.cpp.o): In function main': /Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/main.cpp:14: undefined reference to loop'' when i try compile the code. But other than that error, which i will get round to try sorting later, is it looking more likely to be functional?
#include <Wire.h>
#include "RTClib.h"
RTC_DS1307 rtc;
// Output
// Color arrays
int black[3]  = {
  0, 0, 0 };
int dawnone[3] = {
  98,90,70};
int dawntwo[3]    = {
  95, 40, 20 };
  88, 57, 30 };
  100, 97, 100 };
int sun[3] = {
  100, 100, 100 };
int noon[3] = {
  100, 100, 97 };
int duskone[3] = {
  97,85,56};
int dusktwo[3] = {
  20,40,78};
int blueone[3] = {
  0,30,70};
int bluetwo[3] = {
  10,10,70};
// etc.
int wait = 1000;      // 10ms internal crossFade delay; increase for slower fades
int prevR = redVal;
int prevG = grnVal;
int prevB = bluVal;
#ifdef AVR
    Wire.begin();
#else
#endif
    rtc.begin();
  void loop()  ;
    Serial.print('/');
    Serial.print('/');
    Serial.print(' ');
    Serial.print(':');
    Serial.print(':');
    Serial.print('/');
    Serial.print('/');
    Serial.print(' ');
    Serial.print(':');
    Serial.print(':');
    delay(3000);
      if (now.hour(), 7)
        crossFade(dawntwo);
      if (now.hour(),8)
        crossFade(dawnone);
      if (now.hour(), 9)
      if (now.hour(),10)
      if (now.hour(),11)
        crossFade(sun);
      if (now.hour(),12)
        crossFade(noon);
      if (now.hour(),13)
        crossFade(sun);
      if (now.hour(),20)
        crossFade(duskone);
      if (now.hour(),21)
        crossFade(black);
      if(now.hour(),22)
        crossFade(dusktwo);
      if (now.hour(),23)
        crossFade(blueone);
      if(now.hour(),0)
        crossFade(bluetwo);
      if(now.hour(),1)
        crossFade(black);
        j += 1;
        delay(3000);
 *   ten steps.
 * G   +   +   +   +   +
 * B     -     -     -
  return step;
      val += 1;
      val -= 1;
  if (val > 255) {
    val = 255;
  else if (val < 0) {
    val = 0;
  return val;
  // Convert to 0-255
        Serial.print(i);
      DEBUG += 1;
  prevR = redVal;
  prevG = grnVal;
  prevB = bluVal;
  void loop()  ;
Function DECLARATIONS do not have semicolons.
ok, so the code now is
#include <Wire.h>
#include "RTClib.h"
RTC_DS1307 rtc;
// Output
// Color arrays
int black[3]  = {
  0, 0, 0 };
int dawnone[3] = {
  98,90,70};
int dawntwo[3]    = {
  95, 40, 20 };
  88, 57, 30 };
  100, 97, 100 };
int sun[3] = {
  100, 100, 100 };
int noon[3] = {
  100, 100, 97 };
int duskone[3] = {
  97,85,56};
int dusktwo[3] = {
  20,40,78};
int blueone[3] = {
  0,30,70};
int bluetwo[3] = {
  10,10,70};
// etc.
int prevR = redVal;
int prevG = grnVal;
int prevB = bluVal;
int main(){}
#ifdef AVR
    Wire.begin();
#else
#endif
    rtc.begin();
    Serial.print('/');
    Serial.print('/');
    Serial.print(' ');
    Serial.print(':');
    Serial.print(':');
    Serial.print('/');
    Serial.print('/');
    Serial.print(' ');
    Serial.print(':');
    Serial.print(':');
    delay(3000);
      if (now.hour(), 7)
        crossFade(dawntwo);
      if (now.hour(),8)
        crossFade(dawnone);
      if (now.hour(), 9)
      if (now.hour(),10)
      if (now.hour(),11)
        crossFade(sun);
      if (now.hour(),12)
        crossFade(noon);
      if (now.hour(),13)
        crossFade(sun);
      if (now.hour(),20)
        crossFade(duskone);
      if (now.hour(),21)
        crossFade(black);
      if(now.hour(),22)
        crossFade(dusktwo);
      if (now.hour(),23)
        crossFade(blueone);
      if(now.hour(),0)
        crossFade(bluetwo);
      if(now.hour(),1)
        crossFade(black);
        j += 1;
        delay(3000);
 *   ten steps.
 * G   +   +   +   +   +
 * B     -     -     -
  return step;
      val += 1;
      val -= 1;
  if (val > 255) {
    val = 255;
  else if (val < 0) {
    val = 0;
  return val;
  // Convert to 0-255
        Serial.print(i);
      DEBUG += 1;
  prevR = redVal;
  prevG = grnVal;
  prevB = bluVal;
I'm not seeing anything on the serial monitor, like i was when i just used the ds1307 code, which i copied into this sketch.
Actually they do.
Actually they do.
You care to site a single example?
Can't make up your mind which speed to use?
Well, do you? Apparently not, since you didn't #define DEBUG.
Where I come from function declarations have semicolons, function definitions do not.
