DS1307 rtc stoped working
Hi everybody!
I’m currently working on a project, where I want to run an Arduino with several Sensors for a few weeks. I also keep track of the current time with the DS1307 rtc. It all worked fine until I tried to include a sleeping mode a few hours ago. Now the rtc isn’t working properly, it tells me that “RTC is NOT running!”. I tried a few solutions (checked the wiring of the rtc, tried to undo the changes of the bit of code i introduced) but so far nothing worked… I hope you have some better ideas.
Here is the sleeping mode code:
// **** INCLUDES *****
#include “LowPower.h”
// No setup is required for this library
// Enter power down state for 8 s with ADC and BOD module disabled
LowPower.powerDown(SLEEP_1S, ADC_OFF, BOD_OFF);
// Do something here
// Example: Read sensor, data logging, data transmission.
And the test code for the rtc i’m now using:
// Date and time functions using a DS1307 RTC connected via I2C and Wire lib
#include <Wire.h>
#include “RTClib.h”
DS1307 rtc;
void setup () {
Serial.begin(57600);
#ifdef AVR
Wire.begin();
#else
Wire1.begin(); // Shield I2C pins connect to alt I2C bus on Arduino Due
#endif
rtc.begin();
if (! rtc.isrunning()) {
Serial.println(“RTC is NOT running!”);
// following line sets the RTC to the date & time this sketch was compiled
void loop () {
DateTime now = rtc.now();
Serial.print(now.year(), DEC);
Serial.print(’/’);
Serial.print(now.month(), DEC);
Serial.print(’/’);
Serial.print(now.day(), DEC);
Serial.print(’ ‘);
Serial.print(now.hour(), DEC);
Serial.print(’:’);
Serial.print(now.minute(), DEC);
Serial.print(’:’);
Serial.print(now.second(), DEC);
delay(3000);
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Can you please post a copy of your circuit, in CAD or a picture of a hand drawn circuit in jpg, png
Have you googled arduino rtc sleep mode
What model Arduino are you using?
Hi Tom,
thanks for the quick answer. Sorry, I'll do better when i post code again :wink:
I'm using an arduino uno. The circuit isn't the problem, it worked perfectly fine the last weeks, until now... (I also checked the I2C address, it's 0x68 (as it should be)). I googled for the last few hours, but nothing useful came up...
Well how are you powering the RTC, it should be powered by your supply, and have a backup battery?
Tom... :slight_smile:
I'm using this shield:
and I power my arduino with my laptop. I also put the 3V battery in the socket
It may be that the I2C link does not re-establish on wakeup.
google. arduino I2c in sleep mode
Tom.... :slight_smile:
Thanks for your help! For some reason removing the battery and restarting my laptop solved the problem :slight_smile:
