DS18B20 Class
Hello!
Can any one help me in resolving the problem i have in code.
'class DS18B20' has no member named 'begin'
By the way i have alreadyinstalled the libary and still having the problem.
Thanks
It looks to me like the DS18B20 library you have installed has no "begin" member.
Just a hunch.
Your duplicate post that you appended to an old topic has been deleted
Cross-posting is against the rules of the forum. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend 15 minutes (or more) writing a detailed answer on this topic, without knowing that someone else already did the same in the other topic.
Repeated cross-posting will result in a suspension from the forum.
In the future, please take some time to pick the forum board that best suits the topic of your question and then only post once to that forum board. This is basic forum etiquette, as explained in the sticky "How to use this forum - please read." post you will find at the top of every forum board. It contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
Sorry about that actually its my first time with forum and i dont have enough knowledge about that.
Sorry
Here is the code that i'm using .
/* This code is to use with DS18b20 Temperature sensor
  • It shows the temperature in °C or °F on the serial monitor
#include <OneWire.h>
#include <DS18B20.h>
OneWire oneWire(2);
DS18B20 sensor(&oneWire);
float f;
void setup(void)
sensor.begin();
void loop(void)
sensor.requestTemperatures();
while (!sensor.isConversionComplete());
Serial.print("Temperature:");
Serial.print("\t");
// Serial.print(sensor.getTempC()); //Uncomment these lines to print in °C
// Serial.println(" °C");
f=(sensor.getTempC() * 1.8) + 32; //°F
Serial.print(f);
Serial.println(" °F");
Please look at this sticky topic at the top of the page Read this before posting a programming question and follow the instructions on how to post code. Unless, of course, your code really does have a smiley in it
