I've managed to solve the above problem & thought I would post here in case anybody had the same problem.
This sketch was used to transmit temps from an Uno to a Mega but I've only listed the sketch part that deals with the subject listed above to keep this posting within the limits.
It may not be the most elegant or efficient solution but it works. I can simulate 1 or more device failures with no change to the default name allocated to each failed device, which was my initial requirement.
At the receive end, a missing/failed temp sensor shows a reading of -127C at the original sensor position which I can use
//ARDUINO 1.0 ONLY
//MAX NUMBER OF DS18B20 SENSORS IS 11 -- MAX NUMBER OF BYTES Tx = 32; 10 BYTES FOR HEADER & 2 BYTES FOR EACH SENSOR
#include <OneWire.h>
#include <DallasTemperature.h>
#define ONE_WIRE_BUS_PIN 7
OneWire oneWire(ONE_WIRE_BUS_PIN);
DallasTemperature sensors(&oneWire);
// Assign the addresses of your 1-Wire temp sensors.
DeviceAddress dev0 = { 0x28, 0x18, 0x64, 0xAA, 0x04, 0x00, 0x00, 0xC6 };
DeviceAddress dev1 = { 0x28, 0xE6, 0x4F, 0x08, 0x03, 0x00, 0x00, 0xFB };
DeviceAddress dev2 = { 0x28, 0x7A, 0x60, 0x08, 0x03, 0x00, 0x00, 0xA0 };
DeviceAddress dev3 = { 0x28, 0x9A, 0x47, 0xAA, 0x04, 0x00, 0x00, 0xF4 };
DeviceAddress dev4 = { 0x28, 0x55, 0x52, 0xAA, 0x04, 0x00, 0x00, 0xE1 };
DeviceAddress dev5 = { 0x28, 0xD8, 0x34, 0xAB, 0x04, 0x00, 0x00, 0x43 };
DeviceAddress dev6 = { 0x28, 0x53, 0x44, 0xAA, 0x04, 0x00, 0x00, 0xB3 };
DeviceAddress dev7 = { 0x28, 0x5B, 0x70, 0xAA, 0x04, 0x00, 0x00, 0x89 };
DeviceAddress dev8 = { 0x28, 0x18, 0x76, 0xAB, 0x04, 0x00, 0x00, 0xB6 };
DeviceAddress dev9 = { 0x28, 0xA3, 0x75, 0xAB, 0x04, 0x00, 0x00, 0x07 };
DeviceAddress dev10 = { 0x28, 0xA3, 0xE6, 0xAA, 0x04, 0x00, 0x00, 0x71 };
//read order of devices on breadboard
//DeviceAddress dev0, dev5, dev4, dev3, dev6, dev2, dev9, dev10, dev1, dev8, dev7;
// start serial port to show results
Serial.print("Initializing Temperature Control Library Version ");
Serial.println(DALLASTEMPLIBVERSION);
// Initialize the Temperature measurement library
sensors.begin();
// set the resolution to 9 bit (Can be 9 to 12 bits .. lower is faster)
//9-bit=0.50C steps, 10-bit=0.25C steps, 11-bit=0.125C steps, 12-bit=0.0625C steps
//Temp Conversion Time (tconv):-
//9-bit = 93.75ms, 10-bit = 187.5ms, 11-bit = 375ms & 12-bit = 750ms
sensors.setResolution(dev0, 9);
sensors.setResolution(dev1, 9);
sensors.setResolution(dev2, 9);
sensors.setResolution(dev3, 9);
sensors.setResolution(dev4, 9);
sensors.setResolution(dev5, 9);
sensors.setResolution(dev6, 9);
sensors.setResolution(dev7, 9);
sensors.setResolution(dev8, 9);
sensors.setResolution(dev9, 9);
sensors.setResolution(dev10, 9);
Serial.println("RF24 Network Tx from Uno");
SPI.begin();
radio.begin();
network.begin(/*channel*/ 80, /*node address*/ this_node);
}//--(end setup )---
void loop(void)
delay(2000);
int progVer = 12;
Serial.print("Program Version: ");
Serial.println(progVer);
Serial.println("");
unsigned int deviceErrorCounter = 0;
unsigned int numberOfDevices = 11; // Number of temperature devices installed on bus
// Command all devices on bus to read temperature
//delay chosen to suit device resolution (9-bit = 93.75ms, 10-bit = 187.5ms, 11-bit = 375ms & 12-bit = 750ms)
sensors.requestTemperatures();
int temp0 = (sensors.getTempC(dev0));
delay(100);
int temp1 = (sensors.getTempC(dev1));
delay(100);
int temp2 = (sensors.getTempC(dev2));
delay(100);
int temp3 = (sensors.getTempC(dev3));
delay(100);
int temp4 = (sensors.getTempC(dev4));
delay(100);
int temp5 = (sensors.getTempC(dev5));
delay(100);
int temp6 = (sensors.getTempC(dev6));
delay(100);
int temp7 = (sensors.getTempC(dev7));
delay(100);
int temp8 = (sensors.getTempC(dev8));
delay(100);
int temp9 = (sensors.getTempC(dev9));
delay(100);
int temp10 = (sensors.getTempC(dev10));
//The above (devo, dev1...etc) are in their physical location on the breadboard
//read order of above devices on breadboard detected as:-
//dev0, dev5, dev4, dev3, dev6, dev2, dev9, dev10, dev1, dev8, dev7;
int temp20;
int temp21;
int temp22;
int temp23;
int temp24;
int temp25;
int temp26;
int temp27;
int temp28;
int temp29;
int temp30;
//remaps temperature read from sensors to correct device (dev0, dev1...etc)
temp20 = temp0;
temp21 = temp5;
temp22 = temp4;
temp23 = temp3;
temp24 = temp6;
temp25 = temp2;
temp26 = temp9;
temp27 = temp10;
temp28 = temp1;
temp29 = temp8;
temp30 = temp7;
Serial.print(" probe0 Address: ");
printAddress(dev0);
Serial.print(" Temperature: ");
temp0;// printTemperature(dev0);
Serial.print(temp0);
Serial.println("C");
Serial.print(" probe1 Address: ");
printAddress(dev1);
temp1; //printTemperature(dev1);
Serial.print(temp1);
Serial.print(" probe2 Address: ");
printAddress(dev2);
temp2;//printTemperature(dev2);
Serial.print(temp2);
Serial.print(" probe3 Address: ");
printAddress(dev3);
temp3;//printTemperature(dev3);
Serial.print(temp3);
Serial.print(" probe4 Address: ");
printAddress(dev4);
temp4;//printTemperature(dev4);
Serial.print(temp4);
Serial.print(" probe5 Address: ");
printAddress(dev5);
temp5;//printTemperature(dev5);
Serial.print(temp5);
Serial.print(" probe6 Address: ");
printAddress(dev6);
temp6;//printTemperature(dev6);
Serial.print(temp6);
Serial.print(" probe7 Address: ");
printAddress(dev7);
temp7;//printTemperature(dev7);
Serial.print(temp7);
Serial.print(" probe8 Address: ");
printAddress(dev8);
temp8;//printTemperature(dev8);
Serial.print(temp8);
Serial.print(" probe9 Address: ");
printAddress(dev9);
temp9;//printTemperature(dev9);
Serial.print(temp9);
Serial.print("probe10 Address: ");
printAddress(dev10);
temp10;//printTemperature(dev10);
Serial.print(temp10);
//prints the number of devices on the 1-wire bus
int sizeofpayload;
Serial.println("");
Serial.print("Number of devices initially installed on 1-wire bus = ");
Serial.println(numberOfDevices);
Serial.println("Getting temperatures........... ");
// Pump the network regularly
network.update();
// If it's time to send a message, send it!
unsigned long now = millis();
if ( now - last_sent >= interval )
last_sent = now;
//remaps temperatures (temp0, temp1...etc) read from sensors (dev0, dev1...etc) to match
//order for sens0, sens1 ...etc for correct Tx to Mega2560
int sens0 = temp20; //temp20 = temp0;
int sens1 = temp28; //temp28 = temp1
int sens2 = temp25; //temp25 = temp2
int sens3 = temp23; //temp23 = temp3
int sens4 = temp22; //temp22 = temp4
int sens5 = temp21; //temp21 = temp5
int sens6 = temp24; //temp24 = temp6
int sens7 = temp30; //temp30 = temp7
int sens8 = temp29; //temp29 = temp8
int sens9 = temp26; //temp26 = temp9
int sens10 = temp27; //temp27 = temp10
int temps[] = {sens0, sens1, sens2, sens3, sens4, sens5, sens6, sens7,sens8, sens9, sens10}; //this is the Tx payload
Serial.print("Sending...");
payload_t payload = {sens0, sens1, sens2, sens3, sens4, sens5, sens6, sens7, sens8, sens9, sens10};
RF24NetworkHeader header(/*to node*/ other_node);
bool ok = network.write(header,&payload,sizeof(payload));
if (ok)
Serial.println("ok.");
Serial.println("failed.");
Serial.println("");
//--------------(end main loop )---------------------------
/*-----( User-written Functions )-----*/
// function to print a device address
void printAddress(DeviceAddress deviceAddress)
for (uint8_t i = 0; i < 8; i++) //uint8_t means an unsigned integer of length 8 bits
// zero pad the address if necessary
if (deviceAddress[i] < 16) Serial.print("0"); //if less than 16 hex characters then no device
Serial.print(deviceAddress[i], HEX);
//*********( THE END )***********
