DS18B20 Help
Hello,
I've been trying to follow this tutorial on using the DS18B20 temperature sensor:
however, I can upload the program to the Arduino when it's not hooked up to the circuit. But when it is my computer does recognize the device and I can't use the serial monitor. It says it cannot find COM3.
Any ideas?
I'm running windows 7 and an arduino duemilanove
Are you certain that the sensor is connected to digital pin 3?
Positive, I've started experimenting with a IR range finder and reading its output using the serial monitor which works fine.
My temperature sensor also got very very hot so I might of fried it which could maybe explain why its happening.
tried this lib ? - MilesBurton.com - comes with lots of examples...
Indeed - a sensor that measured its own selfheating would be entirely pointless. Sounds like you connected it wrong. Always check and double check pinouts before applying power, its a lot cheaper!
They apparently get hot and destroy themselves if you connect Gnd & 5v the wrong way round......
