GoForSmoke:
afremont:
At some point, it will stop working again. If you have an oscilloscope, you can see how the signal degrades as you pile on sensors. It's not like it's a very clean signal to start with. Long cables will add to your woes because of the capacitance of the wiring. Lower value pull-up resistors will help in many situations. As you already saw, you could go as low as 1k if needed since it was working until you got it below about 500 ohms. The sensors were only designed to sink 4mA which means even 1k is a little small.
You're beyond me but could he use a circuit to drive a led as a line indicator?
Also, couldn't an Arduino support more than one 1-wire bus?
I'm not sure what you mean about the LED. Do you mean as an indicator of activity?
Any pin could be another 1-wire bus, but I don't know if the library supports that or not.
afremont:
Perhaps a difference in brightness would tell something useful about the power line (non-parasite) with X number sensors connected? It would vary as signals are sent but would anyone be able to see that as anything but light level?
If it could then he could tune his power line resistance with a pot.
If DS got the idea that they could sell more devices by supporting more pins, would it happen ASAP?
Reporting
Successfuly connected 22 DS18B20 sensors and one DHT22. I used one 4.7k resistor for those 22 DS18B20 sensors and one 4.7k resistor for that one DHT22.
DHT22 sensor is wired like that:
http://api.ning.com/files/PKFE7DukclQO*V1lbgx2A1Xd*8ffMCvXqAA4Qd-*7J2cFd9DkoZyqDjdIURURatYsNTYNDLc77VSqOklXk-YnQmKI4l6dfie/RHT03arduino1.png
How can i wire multiple DHT22 sensors on Arduino Mega board? Becouse DHT22 data cable has to be each on its own pin, so therefore i have to use as many resistors as there are DHT22 sensors or is there any other way to wire it up? Becouse if that is so, i think there i'll have the same problem as i had with DS18B20 sensors.
There are parallel to serial shift registers. You can read a whole line of bits from the pins on chained shift registers (1 CS on the master to CS chip 1 chains to CS chip 2, etc) as SPI serial at 2 MHz. But, hardware SPI may use pins that 1-wire does so maybe use soft-SPI and 1 MHz speed.
GoForSmoke:
The 1-wire stuff is only in software already, so you can pick any pin you want for it.
(gasperinn) That's cool on the 22 connected. How long is the bus physically?
afremont:
GoForSmoke:
That says yes, hardware SPI can live with 1-wire. 2 buses can cross on a single chip.
OP:
He can wire the DHT22's through a resistor each to the parallel-in side of 3 daisy-chained shift registers on an SPI bus and read, semi-process and store the states of all the DHT22's as bits at SPI speed, 2MB/sec. To read and store 24 bits through SPI would take only 24 cycles, 1.5 usec and you have all your DHT22 lines as digital states. If you do that 1000x a second, you have loads of time to copy the data to SPI between captures, 976 cycles out of 1000.
@afremont, @GoForSmoke, i dont know, every sensor is physically cca. 15m away from the Arduino board, and it is wired with standard UTP network cable
@GoForSmoke, i don't realy understand how do you meen, do you maybe have any shematic picture or something like that?
afremont:
Time to look at the datasheet, it tells all. The only difference is that you have to supply extra power when a temp conversion (or EEPROM write) is in progress. The datasheet shows how to do it, it's simple; it takes an extra i/o pin though. You just enable the pin after issuing the conversion command. That in turn bypasses the pull-up resistor on the data line (Q) so that the device has plenty of power to do the temp conversion or write to its EEPROM. Look at the datasheet, they have a nice write-up on how it all works.
Is that for parasite mode only?
gasperinn:
Using SPI bus shift registers, it would connect like in the Daisy chain SPI configuration here:
The 3 SPI slaves would be 3 8-bit parallel to serial shift registers. A sensor would hook to each input pin which is not shown in the wikipedia diagram. The registers read the digital state from the sensor and on command, copies those as bits. Then the bits are shifted out of the chips and read by the master in as fast as 1.5 microseconds.
The register has its own power line, some people power leds off them on external power.
afremont:
GoForSmoke:
afremont:
Yes it is.
Then a common power line could save an I/O pin ... is that per device?
I don't know if you can save an i/o pin, but you can sure save running an extra wire to all the devices. In parasite mode, the device draws power thru the data pin. The Vcc pin of the device is tied to ground so that the device "knows" that it is in parasite mode. Enough power can be drawn thru the pullup resistor to do most things. However, temp conversions and EEPROM writing need more power than can be sucked thru the resistor in a short time. This is where the microcontroller toggles a pin connected to a transistor that "pulls up" the data line to Vcc bypassing the resistor. Now the sensor on the other end of the wire has all the juice it needs to do the conversion. The datasheet for the sensor goes into great detail about all this.
I would rather the wire than a pin and a wire or many pins and many wires. Using the pin for extra power only when the device works will need a wire regardless and might need many of both.
Why would you need a pin to supply power if you're not running off a pullup?
Is the point of parasite power to reduce power consumption for battery operation?
The dallas 1-wire bus is made up of either 2 or 3 wires with the sensors attached along the bus. One bus wire is ground and one is the data line. The third (optional) wire is to carry a full 5V to the devices. Since the data bus uses a pullup resistor, power can be sourced from the bus by the device. If you ground the normally 5V supply pin on the device, it will draw power from the data line.
Since the data line on the bus has a pullup on it, only a limited amount of current can be supplied to the device. This is fine until the device needs to execute a CONVERT command to sample the temp and measure it. This requires more current than can be drawn thru the data line. So back at the head end of the bus (where the microcontroller is) after issuing a CONVERT command enables full power to the data line by bypassing the pullup resistor. The device can then draw as much current as it needs. After the CONVERT command is finished, the microcontroller disables the pullup bypass so that communications can take place on the data line. This saves running the 5V power wire to each device.
I don't know what you mean about many wires, all devices can reside on one bus. Please just download the document, it explains it all much better.
afremont:
I see that no extra pin is needed. The data pin goes OUTPUT HIGH during the conversion only.
If the device has a conductive chassis you would only need 1 wire.
GoForSmoke:
afremont:
There appears to be a communications gap here, I guess I'm not explaining it effectively. I'd like to think that I know how this stuff works considering I successfully implemented a SEARCH ROM function in PIC assembler about 10 years ago. It's in the public domain, and I wrote it straight from the Dallas flow chart. I have some 1-wire temp sensors on one of my boards right here in front of me and I have used both methods to power the devices in the past.
What you mean by the data line "OUTPUT HIGH" during a conversion only? It does precisely what I said, it expects to be able to draw power from the data line in parasite power mode since the regular power pin is grounded. The microcontroller must assure that sufficient power is available by enabling what Dallas calls a "strong pullup". This is just powering the data line by bypassing the pullup resistor, either by a transistor or some other method that usually requires 1 pin to enable. It all boils down to one thing, if you can afford a pin, you can save on wiring. You'll also have to modify your software to work with it. Speaking of the devil, if you look at the 1-Wire Arduino library you will see that the library author allowed for using parasite power mode.
I wish you much luck with your endeavors to use chassis ground as part of your circuitry. You'll certainly learn allot about dealing with EMI.
The internal pullups of an AVR or PIC are not strong enough to operate the bus normally. I suppose you could switch the data line pin to output mode and power the bus during a conversion or EEPROM write, but it may not be enough current if you have several sensors and you issue a mass temperature convert. In the case of the OP with 20 sensors, it wouldn't be near enough. You'd need another pin and a transistor.
So there's conditions where one way makes more sense than another. Dat's noice.
This becomes interesting when using breakout boards where the 4.7k resistors are mounted on the board itself... This probably means that one is limited to around 10 or so DS18B20's from DFROBOT (see tinyurl.com/b6h6evz) or similar stuff. If you need more than ~10, one should probably use the discrete sensors instead.
