DS18B20 not respond after a CONVERT T command
Dear friends,
I have hooked a DS18B20 to mega128 running at 8MHz int clock, and pulle up 4k7, AT 3.3V. I have included code. Problem is that after issuing a SKIP ROM + CONVERT T command the IC is not responding “pull bus low as convertion is in progress”
Any ideas ?
Thanks a lot
*   File name :DS18B20                                                             *
#include <avr\io.h>
#define  F_CPU 8000000UL
#include <util\delay.h>
#include <avr/pgmspace.h>
#define THERM_CMD_SKIPROM        0xCC                    //SKIP ROM command
#define THERM_CMD_CONVERTTEMP    0x44                    //START CONVERT T command
#define THERM_CMD_READSCRATCHPAD 0xBE                    //READ SCRATCHPAD  command
void DS18B20_Reset (void);
void DS18B20_Command (unsigned char DS_CMD);
* Main Handler        *
* Description: Kernel handler and task manager                                             *
int main(void)
  DDRG  &=~ 0x01;                                     //Setup data direction for PORTA
  PORTG &=~ 0x01;                                     //Setup data output on PORTA
  DDRA=  0xFF;                                        //Setup data direction for PORTA
  PORTA = 0x00;                                       //Setup data output on PORTA
*     Main program loop excecuted here                                         *
*     Foreground process                                           *
for(;;)                                               //Endless loop
 {//--------------------------------------------------//loop point -P1start-
    DS18B20_Reset();                                  //Reset DS18B20
    _delay_us(60);                                    //Delay for 60us
    DS18B20_Command(THERM_CMD_SKIPROM);               //Send SKIP ROM COMMAND
    DS18B20_Command(THERM_CMD_CONVERTTEMP);           //Send CONVERT T COMMAND
     while (bit_is_clear(PING,0))                     //Wait for DS18B20 to complete conversion
         PORTG |= 0x04;                                 //Open led while waiting
       PORTG &=~ 0x04;                                //Close led when conversion completes
         _delay_ms(1);                                  //Delay for 1ms until next sequence
 }//--------------------------------------------------//loop point -P1end-
return 0;
   DDRG  |= 0x01;                                     //Pull bus low
  _delay_us(480);
   DDRG &=~ 0x01;                                     //Release bus
  _delay_us(120);
     while (bit_is_clear(PING,0))                     //Wait for DS18B20 to finish respond
         PORTA |= 0x80;                                 //Open led while waiting
       PORTA &=~ 0x80;                                //Close led when conversion completes
   for (uint8_t i = 0; i < 8; ++i)
         if (bit_is_set(DS_CMD,0))
         _delay_us(6);
         _delay_us(64);
         else if (bit_is_clear(DS_CMD,0))
         _delay_us(60);
         _delay_us(10);
      DS_CMD >>= 1;                                   //Shift next bit right
I think you are missing some code.
Reset, Skip ROM, Convert Command
But, in addition -
Then wait for 750 ms
Then
Reset, Skip ROM, Send Command and then read from the DS1820.
I have tested code at;
http://www.phanderson.com/arduino/
Peter Anderson
