I followed this tutorial DS18B20 Temperature Sensor Arduino Tutorial (4 Examples)
I wired it exactly how they showed and used their exact code(below). I thought maybe it was just a bad connection but i've done just about everything I can to make sure the connections are solid.
Any idea why it's doing this?
Code:
/* DS18B20 1-Wire digital temperature sensor with Arduino example code. More info: https://www.makerguides.com */
// Include the required Arduino libraries:
#include <OneWire.h>
#include <DallasTemperature.h>
// Define to which pin of the Arduino the 1-Wire bus is connected:
#define ONE_WIRE_BUS 2
// Create a new instance of the oneWire class to communicate with any OneWire device:
OneWire oneWire(ONE_WIRE_BUS);
// Pass the oneWire reference to DallasTemperature library:
DallasTemperature sensors(&oneWire);
// Begin serial communication at a baud rate of 9600:
// Start up the library:
sensors.begin();
// Send the command for all devices on the bus to perform a temperature conversion:
sensors.requestTemperatures();
// Fetch the temperature in degrees Celsius for device index:
float tempC = sensors.getTempCByIndex(0); // the index 0 refers to the first device
// Fetch the temperature in degrees Fahrenheit for device index:
float tempF = sensors.getTempFByIndex(0);
// Print the temperature in Celsius in the Serial Monitor:
Serial.print("Temperature: ");
Serial.print(tempC);
Serial.print(" \xC2\xB0"); // shows degree symbol
Serial.print("C | ");
// Print the temperature in Fahrenheit
Serial.print(tempF);
Serial.println("F");
// Wait 1 second:
