DS18B20 Power wiring question
I am powering a DS18B20 externally (not powered by the 5v pin from the Duemilanove I am using) and I cannot get any readings (in either parasitic or non-parasitic power modes) unless I tie the ground in common with the controller. Is this a requirement for this device? My ultimate goal is to transmit the data on the data pin wirelessly.
This is a fundamental requirement for the whole of electronics.
http://www.thebox.myzen.co.uk/Tutorial/Power_Supplies.html
Sorry that is not on as it will require two way communication, you can't do it wirelessley.
