I have attached a DS18B20 temperature sensor to an arduino nano ESP32. I have tried both a 3.3k pullup resistor and a 4.7k pullup resistor, as well as bridged a 10uF ceramic capacitor across VCC and GND of the DS18B20. I've uploaded a basic code to read the temperature which works fine on a regular arduino nano. This is the code:
#include <OneWire.h>
#include <DallasTemperature.h>
#define ONE_WIRE_BUS 9
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
pinMode(LED_BUILTIN, OUTPUT);
sensors.setWaitForConversion(false);
sensors.begin();
Serial.println("DATA FOR DS18B20 TEMPERATURE SENSOR");
sensors.requestTemperatures();
digitalWrite(LED_BUILTIN, HIGH);
Serial.print("Celsius temperature: ");
Serial.print(sensors.getTempCByIndex(0));
Serial.println("°");
digitalWrite(LED_BUILTIN, LOW);
That only read -127, as one wire does not work properly with the nano ESP32 (at least I don't think anyway).
I have also tried the DS18B20 ESP32 library example. This is the code:
// https://github.com/htmltiger/esp32-ds18b20
#include "OneWireESP32.h"
const uint8_t MaxDevs = 2;
float currTemp[MaxDevs];
void tempTask(void *pvParameters){
OneWire32 ds(13, 0, 1, 0); //gpio pin, tx, rx, parasite power
// There are 8 RMT channels (0-7) available on ESP32 for tx/rx
uint64_t addr[MaxDevs];
//uint64_t addr[] = {
// 0x183c01f09506f428,
// 0xf33c01e07683de28,
//to find addresses
uint8_t devices = ds.search(addr, MaxDevs);
for (uint8_t i = 0; i < devices; i += 1) {
Serial.printf("%d: 0x%llx,\n", i, addr[i]);
//char buf[20]; snprintf( buf, 20, "0x%llx,", addr[i] ); Serial.println(buf);
//end
for(;;){
ds.request();
vTaskDelay(750 / portTICK_PERIOD_MS);
for(byte i = 0; i < MaxDevs; i++){
uint8_t err = ds.getTemp(addr[i], currTemp[i]);
if(err){
const char *errt[] = {"", "CRC", "BAD","DC","DRV"};
Serial.print(i); Serial.print(": "); Serial.println(errt[err]);
}else{
Serial.print(i); Serial.print(": "); Serial.println(currTemp[i]);
vTaskDelay(3000 / portTICK_PERIOD_MS);
} // tempTask
xTaskCreatePinnedToCore(tempTask, "tempTask", 2048, NULL, 1, NULL, 0);
void loop() {}
This code puts my board into bootloader mode (the COM port connects and disconnects at one second intervals) so I can't open the serial monitor. It seems like the code is doing weird things to my board.
Does anyone know how I get my DS18B20 working??
EDIT: I have solved it, even though I have selected arduino pin configurations, the DS18B20 only works with legacy pin configurations. I got lucky, I just randomly shoved the data wire into a different GPIO pin and it was the correct one.
