DS18B20 Strange Behaviour Using One Wire
I'm wondering if anyone else has seen the odd behaviour I have when using DS18B20 on one wire and a Mega2560 and what's the solution for it.
I've got a really simple sketch that will eventually form a part of something much bigger. There are six temperature sensors, each is sampled and the temperature is printed to serial monitor. Delay 2 seconds then loop and repeat.
It uses the Dallas temperature library and the One wire library and usually works just fine.
The sensors are supposed to work up to 135 deg.C but when one of them gets above about 75 deg.C it begins to show -127 degC, which is the default value for if the sensor isn't connected. Obviously a slightly duff sensor.
Problem is, all the other sensors on the bus then show -127 deg.C on the next loop. That's going to stuff things up royally when I've got about fifteen sensors on the same digital pin and I'm using some of the outputs for control purposes.
Has anyone come across this before and more importantly, is there a software fix to ignore the output of a rogue sensor and prevent it from corrupting the other values?
Many thanks.
  • Disable waiting for conversion send the request for conversion.
  • Delay for 2 seconds using a millis based TIMER.
  • Retrieve the temperatures.
Repeat …
  • You might want to try to retrieve the temps by addressing each sensor one by one.
  • Do you have the pull-up ?
Yep, I have the 4.7k pullup. I'm already sampling each sensor sequentially using the address rather than getting them all globally and sorting them afterwards.
T1 = sensors.getTempC(sensor1); ................. and so on up to T6.
Are you using disable waiting for conversion
No, what's that Larry?
This is what I do for DS18B20:
// Bla Bla Bla
//                                       s e t u p ( )
  //Start the DS18B20 sensors
  sensors.begin();
  //start a new conversion request
  sensors.setWaitForConversion(false);
  sensors.requestTemperatures();
  sensors.setWaitForConversion(true);
} //END of   setup()
//                                        l o o p ( )
  //************************************************               T I M E R  read temperatures
  //is it time to read the temperature sensors ?
  if (millis() - readTempTime >= 2000ul)
    //restart this TIMER
    readTempTime = millis();
    //read all temperature sensors
    temperatureFreezerC = sensors.getTempC(freezerAddress);
    temperatureOutsideC = sensors.getTempC(outsideAddress);
    // etc.
  }  //END of   read temperatures TIMER
  //other non blocking code
} //END of   loop()
I moved your topic to an appropriate forum category @oldnewby.
In the future, please take some time to pick the forum category that best suits the subject of your topic. There is an "About the _____ category" topic at the top of each category that explains its purpose.
This is an important part of responsible forum usage, as explained in the "How to get the best out of this forum" guide. The guide contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
I have seen this question before (a long time ago).
I think the answer was "fake sensors".
Leo..
