My temp sensor is not working with arduino. I have it hooked up right (I think). When hooked up the on board arduino led goes very dull, and then the USB connection drops out and the arduino is no longer connected to the PC.
When I pull out the ground or the 5V wire from arduino , the led lights back up and the board reconnects to the PC.
If you connect the DS18B20 like the picture (3 wires to the sensor) shows you don't have to use parasite power mode for reading the values because you are powering the device constantly.
