Hi.
I checked the Dallas library and it uses delays so it stop the microcontroller.
Is there any library who use interrupts to retrieve temperature from that sensor?
Hi.
There is a function in the library that allows you to avoid the delay: setWaitForConversion. You have to manage the wait yourself using millis, but it lets you do other work while you're waiting.
I was trying to program the interrupts but Im leaving. I am going to use another microcontroller to handle the polling.
This code does not work. I left here if someone want to use it or take as a reference.
temperature1wire.cpp (7.24 KB)
temperature1wire.h (1.01 KB)
