DS18B20 temperature sensor was showing bad readings. They are above 900, i don't know how convert them to celsius
Welcome to the forum
Please do not post pictures of code
Use code tags (the < CODE/ > icon above the compose window) to make it easier to read and copy for examination
In my experience the easiest way to tidy up the code and add the code tags is as follows
Start by tidying up your code by using Tools/Auto Format in the IDE to make it easier to read. Then use Edit/Copy for Forum and paste what was copied in a new reply. Code tags will have been added to the code to make it easy to read in the forum thus making it easier to provide help.
The DS18B20 is a digital temperature sensor.
The code that you are using is for an analogue temperature sensor, that is the reason that it gives unexpected results.
There is a tutorial about using the DS18B20 at:
https://lastminuteengineers.com/ds18b20-arduino-tutorial/
Your other topic on the same subject deleted.
Please do not duplicate your questions as doing so wastes the time and effort of the volunteers trying to help you as they are then answering the same thing in different places.
Please create one topic only for your question and choose the forum category carefully. If you have multiple questions about the same project then please ask your questions in the one topic as the answers to one question provide useful context for the others, and also you won’t have to keep explaining your project repeatedly.
Repeated duplicate posting could result in a temporary or permanent ban from the forum.
Could you take a few moments to Learn How To Use The Forum
Thank you.
