DS18B20 three sensor system, not returning temperature or addresses (solved)
Hello All,
First time post, so forgive me if I miss a few things. I am using an arduino mega rev2560, and attempting to use three DS18B20 waterproof temperature sensors. The end goal is to record the temperatures every five mutes and write to a data logging shield.
The first set of three sensors I ordered online would not return addresses, and I discovered that the red(power) and white (data) lines were swapped. I bought new sensors from a shop in the nearest city, and still cannot get them to return their factory addresses.
I have attached a picture of the wiring. And the two tutorial sections of code are below.
What am I doing wrong? What else can I try?
// This sketch looks for 1-wire devices and
// prints their addresses (serial number) to
// the UART, in a format that is useful in Arduino sketches
// Tutorial:
// http://www.hacktronics.com/Tutorials/arduino-1-wire-address-finder.html
#include <OneWire.h>
OneWire  ds(3);  // Connect your 1-wire device to pin 3
void setup(void) {
  discoverOneWireDevices();
void discoverOneWireDevices(void) {
  byte i;
  byte present = 0;
  byte data[12];
  byte addr[8];
  Serial.print("Looking for 1-Wire devices...\n\r");
  while(ds.search(addr)) {
    Serial.print("\n\rFound \'1-Wire\' device with address:\n\r");
    for( i = 0; i < 8; i++) {
      Serial.print("0x");
      if (addr[i] < 16) {
        Serial.print('0');
      Serial.print(addr[i], HEX);
      if (i < 7) {
        Serial.print(", ");
    if ( OneWire::crc8( addr, 7) != addr[7]) {
        Serial.print("CRC is not valid!\n");
        return;
  Serial.print("\n\r\n\rThat's it.\r\n");
  ds.reset_search();
  return;
void loop(void) {
  // nothing to see here
// This Arduino sketch reads DS18B20 "1-Wire" digital
// temperature sensors.
// Tutorial:
// http://www.hacktronics.com/Tutorials/arduino-1-wire-tutorial.html
#include <DallasTemperature.h>
// Data wire is plugged into pin 3 on the Arduino
#define ONE_WIRE_BUS 11
// Setup a oneWire instance to communicate with any OneWire devices
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
// Assign the addresses of your 1-Wire temp sensors.
// See the tutorial on how to obtain these addresses:
DeviceAddress outsideThermometer = { 0x28, 0x3C, 0xC0, 0x08, 0x03, 0x00, 0x00, 0x54 };
//DeviceAddress outsideThermometer = { 0x28, 0x6B, 0xDF, 0xDF, 0x02, 0x00, 0x00, 0xC0 };
//DeviceAddress dogHouseThermometer = { 0x28, 0x59, 0xBE, 0xDF, 0x02, 0x00, 0x00, 0x9F };
void setup(void)
  // start serial port
  // Start up the library
  sensors.begin();
  // set the resolution to 10 bit (good enough?)
  sensors.setResolution(outsideThermometer, 11);
//  sensors.setResolution(outsideThermometer, 10);
//  sensors.setResolution(dogHouseThermometer, 10);
void printTemperature(DeviceAddress deviceAddress)
  float tempC = sensors.getTempC(deviceAddress);
  if (tempC == -127.00) {
    Serial.print("Error getting temperature");
    Serial.print("C: ");
    Serial.print(tempC);
//    Serial.print(" F: ");
//    Serial.print(DallasTemperature::toFahrenheit(tempC));
void loop(void)
  delay(2000);
  Serial.print("Getting temperatures...\n\r");
  sensors.requestTemperatures();
  Serial.print("Outside temperature is: ");
  printTemperature(outsideThermometer);
  Serial.print("\n\r");
//  Serial.print("Outside temperature is: ");
//  printTemperature(outsideThermometer);
//  Serial.print("\n\r");
//  Serial.print("Dog House temperature is: ");
//  printTemperature(dogHouseThermometer);
//  Serial.print("\n\r\n\r");
You haven't wired the data pin correctly. The orange wire to pin 11 should connect directly to the white data wire and the resistor should connect between the white data wire and the red (+) power rail.
Your first example code uses pin 3 instead of pin 11.
Pete
Thank you very much Pete!
N
