I using x2 ds18b20's, 1 is a water proof and the other is To92. The water proof is for the aquarium and the other is on the circuit board monitoring the pcb temp as its in a sealed enclosure. The pcb ds18b20 runs a small 12v pc fan, mapped is sketch between a temp range. both sensors are identified via Index.
The issue I have is should a sensor fail, the index swaps theyre numbers and my displays swap around.
Id like to identify both sensors as theyre individual address should a sensor fail. Ive looked online for examples but im really confused.
Is there someone that could help me understand how to identify them via adresses please.
Always show us a good schematic of your proposed circuit.
Show us a good image of your ‘actual’ wiring.
Give links to components.
In the Arduino IDE, use Ctrl T or CMD T to format your code then copy the complete sketch.
Use the < CODE / > icon from the ‘posting menu’ to attach the copied sketch.
What are the sensor addresses ?
yeah I know. I havent because the pcb was made on Fritzing and the schem is all up the shit. Itll take me some time to redo it. Ive attached my code however.
[code]
********* DOLPHIN TANK ******************
//#include "Arduino.h"
#include <uRTCLib.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#define ONE_WIRE_BUS 4
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
LiquidCrystal_I2C lcd1(0x26,16,2); // time/date LCD
LiquidCrystal_I2C lcd2(0x27,16,2); // temp/fan LCD
uRTCLib rtc(0x68);
int PCBfanPin = 10; // digital PCB fan o/p
int PWMfanPin = 9; // digital fan o/p
int buzzerPin = 2; // digital alarm o/p
int sensorCount = 0;
int PWMval;
int PCBfanPWMval;
int fanSpeed;
int fanState;
int PCBfanSpeed;
float CorrectedTemp;
float PCBtemp;
//******************************** MAIN SETTINGS **********************************************************************
float PCBfanTempMin = 28; // temp when PCB fan begins
float PCBfanTempMax = 35; // temp when PCB fan at 100%
int tempMin = 26; // temp when fans begin
int tempMax = 28; // temp when fans at 100%
float lowTMPalarm = 24.5; // min temp alarm sounds
float highTMPalarm = 28; // max temp alarm sounds
int PCBFanPWMvalMin = 20; // adjustment for MIN PCB fan speed
int PCBFanPWMvalMax = 255; // adjustment for MAX PCB fan speed
int mainFanPWMvalMin = 50; // adjustment for MIN fan speed
int mainFanPWMvalMax = 255; // adjustment for MAX fan speed
float CalibrateTemp = 2.2; // manual temp calibration +2.2deg
//******************************** ALARM SETTINGS **********************************************************************
// morning purge time
int AlarmHour1 = 5;
int AlarmMinute1 = 30;
// evening purge time
int AlarmHour2 = 17;
int AlarmMinute2 = 30;
// The following 2 lines create a window due to the time lag of the temp sensors.
// It ensures the alarm goes off without missing the selected time.
// Note: PrimePurge must be longer than "timeSecond" window to eliminate double purging.
int timeSecondMin = 0;
int timeSecondMax = 10;
//******************************** INITIAL TIME SETTINGS *************************************************************
void SetTime()
// (Seconds,Minute,Hour,Weekday,Date,Month,Year);
// highlight following line to initialize time
// rtc.set(00,58,05,6,20,6,23);
void PrintLCDTimeDisplay()
lcd1.setCursor(0,0);
lcd1.print("Time:");
lcd1.setCursor(0,1);
lcd1.print("PCB Temp: ");
void PrintLCDtempDisplay()
lcd2.setCursor(0,0);
lcd2.print("Temp: ");
lcd2.setCursor(0,1);
lcd2.print("Fan Speed: ");
void TimePCBtempResultsLCD()
rtc.refresh();
lcd1.setCursor(6,0);
if (rtc.hour() <10) lcd1.print("0");
lcd1.print(rtc.hour()); lcd1.print(":");
if (rtc.minute() <10) lcd1.print("0");
lcd1.print(rtc.minute()); lcd1.print(" ");
lcd1.setCursor(10,1);
lcd1.print(PCBtemp,1);
lcd1.print((char)223);
lcd1.print("C");
void TempFanResultsLCD()
lcd2.setCursor(6,0);
lcd2.print(CorrectedTemp);
lcd2.print((char)223);
lcd2.print("C ");
lcd2.setCursor(11,1);
lcd2.print(fanSpeed);
lcd2.print("% ");
void PurgeFans()
Serial.print("Drying fans");
lcd2.clear();
lcd2.print("Drying Fans");
for (int t=5; t>0; t--)
digitalWrite(PWMfanPin, HIGH);
delay(3000);
digitalWrite(PWMfanPin, LOW);
delay(3000);
PrintLCDtempDisplay();
void CheckPurgeTimes()
if ((rtc.hour() == AlarmHour1) &&
(rtc.minute() == AlarmMinute1) &&
(rtc.second() >= timeSecondMin) &&
(rtc.second() <= timeSecondMax) &&
(fanState == 0))
PurgeFans();
if ((rtc.hour() == AlarmHour2) &&
(rtc.minute() == AlarmMinute2) &&
(fanState == 0))
PurgeFans();
void checkTMPerror()
if (CorrectedTemp <= lowTMPalarm)
Serial.println("LOW WATER TEMP");
for (int t=2; t>0; t--)
lcd2.print("LOW TEMP! ");
digitalWrite(buzzerPin, HIGH);
digitalWrite(buzzerPin, LOW);
lcd2.print(" ");
lcd2.print(" ");
if (CorrectedTemp >= highTMPalarm)
Serial.println("HIGH WATER TEMP");
lcd2.print("HIGH TEMP ");
lcd2.print(" ");
lcd2.print("HIGH TEMP! ");
lcd2.print(" ");
void MainFanControl()
if (CorrectedTemp < tempMin)
fanState = 0; // meets purge fans requirements
PWMval = 0;
fanSpeed = 0;
if (CorrectedTemp > tempMax)
fanState = 1; // does not meet purge fans requirements
PWMval = mainFanPWMvalMax;
fanSpeed = 100;
PWMval = map (CorrectedTemp * 10, tempMin * 10, tempMax * 10, mainFanPWMvalMin, mainFanPWMvalMax);
fanSpeed = map (CorrectedTemp * 10, tempMin * 10, tempMax * 10, 1, 100);
analogWrite(PWMfanPin, PWMval);
Serial.print(rtc.day()); Serial.print('/'); Serial.print(rtc.month()); Serial.print('/'); Serial.print(rtc.year());
Serial.print(" ");
Serial.print(rtc.hour()); Serial.print(':');
if (rtc.minute() <10) Serial.print("0");
Serial.print(rtc.minute()); Serial.print(':');
if (rtc.second() <10) Serial.print("0");
Serial.print(rtc.second());
Serial.print("Water Temp: "); Serial.print(CorrectedTemp); Serial.print("°C");
Serial.print(", Fan Speed: "); Serial.print(fanSpeed); Serial.print("%, ");
Serial.print("PWMval: "); Serial.print(PWMval);
Serial.print(", Fan State "); Serial.print(fanState);
void runPCBfan()
if (PCBtemp < PCBfanTempMin)
PCBfanPWMval = 0;
PCBfanSpeed = 0;
digitalWrite(PCBfanPin, LOW);
if (PCBtemp > PCBfanTempMax)
PCBfanPWMval = PCBfanTempMax;
PCBfanSpeed = 100;
digitalWrite(PCBfanPin, HIGH);
PCBfanPWMval = map (PCBtemp *10, PCBfanTempMin*10, PCBfanTempMax*10, PCBFanPWMvalMin, PCBFanPWMvalMax);
PCBfanSpeed = map (PCBtemp * 10, PCBfanTempMin * 10, PCBfanTempMax * 10, 1, 100);
analogWrite(PCBfanPin, PCBfanPWMval);
Serial.print("PCB Temp: "); Serial.print(PCBtemp); Serial.print("°C");
Serial.print(", Fan Speed: "); Serial.print(PCBfanSpeed); Serial.print("%, ");
Serial.print("PWMval: "); Serial.print(PCBfanPWMval);
void RequestTemperatures()
sensors.requestTemperatures();
CorrectedTemp = (sensors.getTempCByIndex(0) + CalibrateTemp);
PCBtemp = (sensors.getTempCByIndex(1));
URTCLIB_WIRE.begin();
sensors.begin();
Serial.print("Found ");
sensorCount = sensors.getDeviceCount();
if (sensorCount == 1)
Serial.print(sensorCount, DEC);
Serial.print(" ds18b20 Temperature Sensor.");
Serial.print(" ds18b20 Temperature Sensors.");
Serial.println("");
lcd1.init();lcd2.init();
lcd1.clear();lcd2.clear();
lcd1.backlight();lcd2.backlight();
pinMode(2, OUTPUT);
pinMode(9, OUTPUT);
pinMode(10, OUTPUT);
//chnages PWM frequency to eliminate fan noise - pins D9 and D10 - 31.4kHz
TCCR1A = 0b00000001; // 8bit
TCCR1B = 0b00000001; // x1 phase correct
fanState = 0;
PrintLCDTimeDisplay();
SetTime();
TimePCBtempResultsLCD();
RequestTemperatures();
MainFanControl();
runPCBfan();
TempFanResultsLCD(); // prints temp and fan speed to LCD2
checkTMPerror(); // checks for Low/High temp
TimePCBtempResultsLCD(); // prints time and PCB temp to LCD1
CheckPurgeTimes();
delay(700);
[/code]
For example, here are a two sensors I used in a project.
//Addresses of the DS18B20s
//Freezer = 0x1035B58A0208009B <-----<<<< change to the appropriate address
uint8_t freezerAddress[8] = {0x10, 0x35, 0xB5, 0x8A, 0x02, 0x08, 0x00, 0x9B};
//Outside = 0x109CC18A02080023 <-----<<<< change to the appropriate address
uint8_t outsideAddress[8] = {0x10, 0x9C, 0xC1, 0x8A, 0x02, 0x08, 0x00, 0x23};
//Freezer temperature
temperatureFreezerC = sensors.getTempC(freezerAddress);
Serial.print(temperatureFreezerC);
Serial.println("ºC");
//Outside temperature
temperatureOutsideC = sensors.getTempC(outsideAddress);
Serial.print(temperatureOutsideC);
//start a new conversion request
sensors.setWaitForConversion(false);
sensors.setWaitForConversion(true);
@RobMormile
1. Connect DS18B20-1/Sensor-1 (the submerged one).
2. Upload the following sketch (not tested) and record its 64-bit (8-byte ROM Code. Attach the address with Sensor-1.
//12-bit default resolution; external power supplyOneWire ds(10); //signal wire
#include<OneWire.h>
OneWire ds(10);
byte addr[8]; //to hold 64-bit ROM Codes of DS1
ds.reset();
ds.search(addr); //collect 64-bit ROM code from sensor (DS1)
for (int i = 0; i < 8; i++)
byte y = addr[i];
if (y < 0x10)
Serial.print('0'); //show leading zero
Serial.print(addr[i], HEX); //show on I2C LCD
void loop() {}
3. Disconnect DS18B20-1 and connect DS18B20-2/Sensor-2 (the open air one)
4. Rerun sketch of Step-2 and record the address and attach it with the Sensor-2.
3. Connect both sensors and upload the following sketch (not tested). Now, you can easily figure out which sensor has failed or malfunctioning.
#include<OneWire.h>
OneWire ds(10);
byte addr1[8]; //to hold 64-bit ROM Codes of DS1
byte addr2[8]; //to ho;d 64-bit ROM-code DS2
byte data[9]; //buffer to hold data coming from DS18B20
float celsius;
ds.reset();
ds.search(addr1); //collect 64-bit ROM code from sensor (DS1)
ds.search(addr2);
probe1();
delay(1000); //sampling interval
probe2();
void probe1()
ds.reset(); //bring 1-Wire into idle state
ds.select(addr1); //slect with DS-1 with address addr1
ds.write(0x44); //conversion command
delay(750); //data ready withinh DS18B20-1 or poll status word
ds.reset();
ds.select(addr1); //selectimg the desired DS18B20-1
ds.write(0xBE); //Function command to read Scratchpad Memory (9Byte)
ds.read_bytes(data, 9); //data comes from DS and are saved into buffer data[8]
int16_t raw = (data[1] << 8) | data[0]; //---data[0] and data[1] contains temperature data : 12-bit resolution-----
celsius = (float)raw / 16.0; //12-bit resolution
Serial.print("Temp from Sensor-1: ");
Serial.println(celsius, 2);
void probe2()
ds.select(addr2); //slect with DS-2 with address addr1
delay(750); //data ready withinh DS18B20-2 or poll status word
ds.reset();
ds.select(addr2); //selectimg the desired DS18B20
Serial.print("Temp from Sensor-2: ");
I assume you know that only the metal part is waterproof, the heatshrink part is not.
The sensor will soon fail if you completely submerge it.
Leo..
been in there for 2 years bud.
lol like that didnt confuse things.
Do you understand the code offered in post #5 ?
If not, what are you have trouble understanding ?
There will be an example sketch which comes with the DS18B20 library that will display the address of the sensor.
Yes. I forgot this draft from before:
The example multiple.ino is useful for gleaning the addresses of the devices on the bus.
Then you can fix the code to use a method that takes an address instead of indexing into a table built at start up, which is where you go,wrong with the sim,er way of handling multiple sensors.
getTempC((uint8_t*) deviceAddress);
a7
