DS18B20 Waterprof temp sensor and DHT11 temp and moisture on same bus??
Is it possible to connect these two sensors on the same bus? i just got the sensors so i havent been able to research it too much but initial searches didnt tell me much on this part.
i would still like to retain the moisture reading since i need that value too.
If not: is it possible to connect two DHT11 on the same pin for separate readings or is this sensor non-bus?
No they use a different protocol. You can have multiple DS18B20 sensors on one bus. Having multiple DHT11s on one pin is not possible because the sensors do not have an addressable feature.
i see thank you, good thing i ordered a Mega for my project i guess :)
